Anyone have any tips for pulling the orange pin out on a swing tongue ramlin trailer? That thing doesn't want to move, I can't believe that you'd have to pound on it everytime you want to swing the tongue back or put the pin back in.
RE: Ramlin Trailer Question
hmmm ... ours works flawlessly.
Check to see that all the holes line up properly. You may have to open up one of the holes that the pin goes through with a round file or dremel. Also make sure the pin and holes are clean. A little grease on the pin doesn't hurt either.
Mine is greased but requires a lever arm (like an end wrench) to twist it back and forth a few times before it comes loose.
I usually need to lift the front end of the tongue to take the pressure off the pin...otherwise it comes out fine.
