I have been using fat sacs for surfing for over ten years and I am tired of the hassle of filling and draining the bags, and getting the storage lockers wet in the boat. I have heard great things about the lead wake bags but I am concerned about the excess fuel burn that 600lbs of lead would cause. This worries me because my family doesn’t only surf. We like to tube and cruise around the lake. Do you guys drop off your lead bags every time you’re done surfing, or do you just leave them in the boat?
I have 750 lbs of lead bags in my G23 and never take out them out . Keep them in your boat and just deal with it. If you are worried about gas consumption you should not be owning a 2021 G23. I love the lead bags , and easier to deal with then fat sacks . Anyway my 2 cents
If.... when you want to save gas while keeping lead in your boat... move it mostly to the bow... you end up with a killer efficient prop shaft angle while cruising.... probably not much than without lead... because at 25mph+ you have such a nose down profile.... giving a much more efficient prop shaft angle.2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
Originally posted by GMLIII View PostI have 750 lbs of lead bags in my G23 and never take out them out . Keep them in your boat and just deal with it. If you are worried about gas consumption you should not be owning a 2021 G23. I love the lead bags , and easier to deal with then fat sacks . Anyway my 2 cents
You guys actually move 600 lbs of lead every time you finish surfing? I have bags piggy backed on the hard tanks push the fill buttons until they time out then push them again to fill the bags. Same thing to empty them I don't see how it can get any easier than that?
I can tell you as a qualified Navy submariner that the boat will sink with the additional water on board also(if it submerges). This is how submarines are ballasted. The neutral bouyancy point is a fine line in relation to un-ballasted weight.
Ian S
Originally posted by XBIGPUN66 View PostI can tell you as a qualified Navy submariner that the boat will sink with the additional water on board also(if it submerges). This is how submarines are ballasted. The neutral bouyancy point is a fine line in relation to un-ballasted weight.
The closed cell foam is designed to allow the boat to survive with factory ballast and normal weight of boating items. The additional amount of lead or water would overcome this safety margin and cause negative buoyancy and submerge the boat in the case of an accident or swamping.
Ian S
I run 600lbs of lead in my G21 and don't really notice a difference in fuel consumption when surfing. I seem to burn about the same amount of fuel whether I have lead, no lead, 4 or 10 in the boat. We all know that more weight burns more fuel but 600lbs doesn't appear to be significant.
I recently went from 450lbs of lead to 850lbs of lead in our 20 g23. 1) the surf wave is much longer and firmer with more push farther back, 2) I can tell getting up on plane the weight is there, and 3) it sucks more gas for sure. I have no idea how much more...when I get low I fill it up and I don’t track it...but it is certainly more thirsty.
I don’t take the lead out...it’s me and the wife and our two boys (9 and 13) most of the time in the boat...maybe a few more kids if they have friends over. It’s likely hurting our tubing mpg also
Sent from my iPhone using Tapatalk Pro
Originally posted by astilley View PostI have been using fat sacs for surfing for over ten years and I am tired of the hassle of filling and draining the bags, and getting the storage lockers wet in the boat. I have heard great things about the lead wake bags but I am concerned about the excess fuel burn that 600lbs of lead would cause. This worries me because my family doesn’t only surf. We like to tube and cruise around the lake. Do you guys drop off your lead bags every time you’re done surfing, or do you just leave them in the boat?
