2013 G23 Throttle
  • davenew12@gmail.com
    • Jul 2017
    • 5
    • Lake Norman NC
    • 2021 G23 2013 G23 2003 Sea Ray 230
    2013 G23 Throttle
    I have a 2013 G23 and don't like the throttle operation. It sticks and struggles to move effortlessly. I've gotten used to it, but guest drivers really struggle to determine if in gear or neutral. My friend has a 2018 G23 and his moves much more freely and is more obvious when it clicks back into neutral. Are there any replacement throttle systems available?
    • 17120
    Anytime I hear about people not being able to determine whether the boat is in gear or in neutral, I always like to verify that they are using the throttle handle correctly. When switching from forward or reverse to neutral, you shouldn't be squeezing the ring. Just move the handle until it locks into neutral. Is that what you and your other drivers are doing?
    If the throttle is sticky and not moving properly, I would say there is definitely something that needs to be looked at. It may be that after six years, the mechanism has gotten gummed up and needs to be cleaned and lubricated.
      • Jul 2017
      • 5
      • Lake Norman NC
      Hi Jeff. Thanks for your comment. I understand and agree with your point that squeezing the ring should only be practiced when switching out of neutral. That is the way I operate the throttle. However, other experienced owners with newer SAN's that have driven my boat agree that my throttle is not operating as it should. I plan to reach out to Race City Marine and seek their assistance. Just wanted to see if other owners are having the same issues.
      • zhadley
        • Sep 2013
        • 58
        • Redlands, CA
        • 2017 GS22 1992 Ski Nautique
        I am in the exact same boat as you. Well not exactly as it is a 2013 210. I hate my throttle. My friends 2017 G23 is so smooth. I've seen this discussed before but never heard of anyone that changed it out or if this was an option. I would be very interested to do it. As you have, I am able to manage as I have gotten used to it. However it is tough for other drivers. Mine is very stiff and hard to tell when it is in neutral. Jeff, I don't use the ring incorrectly, you sometimes even have to jiggle the throttle to find neutral. I have heard this discussed in the past on this site and I believe Jeff said that they went to a new style control in 2014. I don't think it is an issue with it being gummed up either as it has always been this way. Hoping to hear if anyone has a solution for this.
        Zach
        • dales
          • Aug 2011
          • 3
          • Ontario Canada
          • 2014 G21
          We have a 2014 G21 and had to have the throttle replaced twice the first summer we had the boat . Third one finally worked correctly. Sound like the same problems you are having. It was almost impossible to operate and was very dangerous. I think the throttle design was changed in 2015.
          • billybmke
            • Nov 2004
            • 21
            • Unknown
            • 2013 G23
            I had the same issue with my 2013 G23, fine for me because I was used to it, but guest drivers often thought they were in neutral when in fact they were in reverse.
            I just upgraded to a 2019 and it was the very first thing I noticed when I put it in gear...giant improvement! The sales guy said they might have a fix for the old one now.
            • davlivin
              • Sep 2016
              • 8
              • Gainesville GA
              • 2016 G23
              Starting with 21015 or 2016 (I think) throttle went to digital control instead of a cable. I drove a 2013 G23 and it was WAY different.
              • charlesml3
                • Jan 2008
                • 2482
                • Lake Gaston, NC
                • 2022 G23
                Yea. My neighbor has a 2013 G23 and the thottle/shifter is very different. I have to do "the wiggle" to know for sure I'm in neutral. Basically, I let go of the ring and wiggle the the lever forwards and backwards a bit to make SURE I'm in neutral. It's just something you have to get used to on that year-model boat.
                -Charles
                • Kenv
                  • Jan 2004
                  • 1070
                  • Texas
                  It was 2015 for sure.
                  • Cadesun
                    • Aug 2007
                    • 110
                    • Lake Geneva, WI
                    • 2013 SAN 210 TE,,, 1998 Super Sport - sold
                    My 2013 210 has the same issue. The dealer said it was a known problem and was corrected in the 2014 or 2015 models. I just got used to it but you're right, guest drivers have issues some times.
                    • MileHiGuy
                      • Mar 2012
                      • 36
                      • Rocky Mountains
                      • '02 BU 21 Sunscape - Sold '13 G23-550
                      I also have a 2013 and the throttle has always been stiff but it is getting worse and I fear dangerous. Anxious if anyone has found a fix for the first gen G’s
                      • rod
                        • Nov 2013
                        • 2
                        • AZ/CA
                        • 1995 ski nautique (sold) 2013 Nautique 230
                        Reviving and old thread, did anyone figure out a fix or adjustment for the 2013 throttle/shift issues?
                        • kylant
                          • May 2010
                          • 549
                          • Lake Tahoe
                          i have a 2014 and the first engagement is difficult. beyond that it is smooth. i believe mine is the shift cable. i was going to have the dealer inspect it and possibly replace prior to next season. for 2015, it was redesigned
                          • jpwhit
                            • Aug 2016
                            • 650
                            • Cary, NC
                            Looks like MileHiGuy did find a fix. His profile info on the left side bar looks like he sold the boat and hasn't been on the forum for the last 2 years .....
                            • mbaugh
                              • Jul 2009
                              • 18
                              • Lexington, KY
                              • Old: '95 Sport Nautique New: '03 SAN
                              2014 G23 with the same issue here. Very frustrating. Like others I’ve gotten used to it but don’t feel comfortable with anyone driving besides my wife and I. Did anyone reach out to @milehi ? Considered messaging him but didn’t want to bug him if he’s already informed other folks on a fix.
