can anyone tell me how to get just these seadek trim pieces
  • chefred112
    • Jul 2016
    • 98
    • Tracy, CA
    • 1995 Super Sport
    hello all, I saw this super sport online and was wondering if I can just get the trim pieces I circled in the pic...thanks
  • Blamey
    • Sep 2015
    • 595
    • New York
    Nautique parts sells these.
    https://www.nautiqueparts.com/produc...ps-gray-brown/
    Not sure about the rest but you can do a custom order from seadeck. They send you a sheet of mylon, you do a rough trace of you design, they send back a mock up and you check fit and order the part.
    • gobluemike2142
      • Jan 2017
      • 220
      • Michigan, USA
      • '96 SS
      Yeah I like those as well and would be interested if you find them. The other thing to do would be call Roswell or SeaDek. They did a SS promo boat a while back. Too much SD for me but they may have those templates in a computer somewhere. Search "Roswell Super Sport" images and you'll see it.
      • chefred112
        • Jul 2016
        • 98
        • Tracy, CA
        • 1995 Super Sport
        thanks, I contacted them through email and sent them the same pic. we'll see what they say... since this has already been done I would not think I would have to go thru the measuring and template process again.
        • chefred112
          • Jul 2016
          • 98
          • Tracy, CA
          • 1995 Super Sport
          thanks for this, I may order xtra's of this for the gunnels...
          • homer12
            • Feb 2016
            • 584
            • Indianapolis, IN
            • 2004 SV211 TE
            Give scwake.com a try too. Good people and good customer service. They can do any shape custom you need.
            • trip33
              • Nov 2010
              • 248
              • Odessa, FL
              +1 for SCwake.
              • brit_hunsicker
                • Oct 2014
                • 482
                • Overbrook, KS
                • 2001 Super Air Nautique
                Check out my thread “2001 Super Air Nautique Seadek Templates”
                I know yours won’t be identical. But there is a guy who called the place that did mine and got a few things changed to make it right for his year. His turned out great and is more similar to the picture above as far as tower.
                • brit_hunsicker
                  • Oct 2014
                  • 482
                  • Overbrook, KS
                  https://www.planetnautique.com/vb5/f...adek-templates
                  • brit_hunsicker
                    • Oct 2014
                    • 482
                    • Overbrook, KS
                    Here is what Rusty Barras did. He used my templates and made a couple changes with Dek Designs to fit his boat. We are both very satisfied. Several people have copied my templates with no issues.
                    • chefred112
                      • Jul 2016
                      • 98
                      • Tracy, CA
                      • 1995 Super Sport
                      perfect!! thanks man! exactly what I was looking for...I'll research further after I go thru your thread!!
                      • ScooterMcgavin
                        • 1540
                        • 2014 SAN 210 TE
                        That does look real nice!
                        1989 Sport Nautique
                        • Wildcat04
                          • Jun 2017
                          • 43
                          • Wichita, KS
                          • 1997 Air Natique
                          I used Gatorstep. They sent me Mylar, I made the templates, went back and forth a few times with the designer, they sent out paper test pieces, back with the designer for final layout, then pieces cut and back to me. The whole process took right at a month. I was extremely happy with the folks I worked with at Gatorstep
                          • pokesgrad02
                            • Aug 2012
                            • 170
                            • Lenexa
                            • 2018 SAN 230
                            You will likely have to do the Mylar trace no matter who you use. SeaDek doesn’t want the liability of sending you something that isn’t perfect. It’s a process but well worth the effort. I too had to go back a forth a couple times to get a fit that I liked
