Discussion with Nautique regarding the replacement for Pebble watch
  • charlesml3
    • Jan 2008
    • 2487
    • Lake Gaston, NC
    • 2022 G23
    #211
    Originally posted by JRW160 View Post
    This works on the Garmin D2 Delta watch as well
    For proper visibility and search capabilities, you should start a new thread. Maybe something like "Surf Select on older Garmin Watches" or something. I think that would keep the discussion focused.
    -Charles
    • Proedge
      • Jul 2020
      • 50
      • British Columbia
      #212
      So none of the 2019 boats got Surf Select 3.0? I'm picking up a 2019, which had an in-service date in April of 2020. Not sure when it was actually manufactured, but I'm wondering which module it has in it. I want to order a Pebble watch if that's what I will need for it. I don't really want to change out the surf select module; and from reading this thread I like that the Pebble has the Next Track option, whereas Garmin does not. Unless there has been an update since this thread.
      • charlesml3
        • Jan 2008
        • 2487
        • Lake Gaston, NC
        • 2022 G23
        #213
        I do not believe there were any 2019s with Surf Select 3.0. It was introduced with the MY2020 boats. The best way to check is to inspect the Surf Select module. It'll have a sticker on the cable with the version number. You can also see it in the LINC under the firmware display.
        -Charles
        • mkaspro
          • Feb 2013
          • 10
          • United States
          #214
          Nope would not function. Watch has to have buttons vs touch screen since the watch is exposed to a water environment
          Thats not true at all, we control the stereo using our apple watches all the time. Works great.
          • GMLIII
            • May 2013
            • 2821
            #215
            mkaspro but Apple will not function with Surf Select . Only Pebble or Garmin. You are the man although
            • mkaspro
              • Feb 2013
              • 10
              • United States
              #216
              Quote removed by Admin for not following the Guidelines for Quoting Previous Posts in a Thread.
              Yeah sadly thats true, people were just saying Nautique 'cant' support the Apple Watch because it doesnt have buttons and therefore will not work in water. It absolutely works in water. *Why* Nautique refuses to ever do any integration with them is the part that baffles me.
              We never buy surf select anymore because I hate carrying the remote, but if it worked with the watches we'll probably already have on, I'd definitely pay for it.
              • GMLIII
                • May 2013
                • 2821
                #217
                mkaspro If the Apple watch works with your sound system, it would not work with the other features associated with Surf Select
                • mkaspro
                  • Feb 2013
                  • 10
                  • United States
                  #218
                  I was purely commenting on it 'working in water and not having physical buttons'. It works with the stereo, phone, my garage door open, and tons of other things. It *could* work with the boat if Nautique wanted it to.
                  • charlesml3
                    • Jan 2008
                    • 2487
                    • Lake Gaston, NC
                    • 2022 G23
                    #219
                    Originally posted by mkaspro View Post
                    [SIZE=10px]
                    I asked one of the Nautique reps about this at a boat show. They said they tried the Apple Watch and several other touchscreen watches and they worked, but not reliably with wet hands. That's why they originally picked Pebble and then went on to Garmin.
                    -Charles
                    • Proedge
                      • Jul 2020
                      • 50
                      • British Columbia
                      #220
                      I don't see why they don't make something like the Land Rover "Activity Key" instead of a remote you have to hold for Surf Select.
                      • GMLIII
                        • May 2013
                        • 2821
                        #221
                        Proedge They do, you either use a Pebble watch or Garmin watch depending on the module type of Surf Select you have in your Nautique. The handheld device is garbage . The watches have so many more features to use behind Nautiques then the handheld devices
                        • Proedge
                          • Jul 2020
                          • 50
                          • British Columbia
                          #222
                          I know you can use a third party watch, I just mean why don't they supply something like the Land Rover one from the factory.
                          • GMLIII
                            • May 2013
                            • 2821
                            #223
                            Proedge Don't know
                            • pitts12driver
                              • Oct 2009
                              • 85
                              • San Francisco, CA
                              • 2022 G23
                              #224
                              2 weeks ago, I actually introduced the CEO of Nautique to the head of the Apple Watch team, and Nautique basically said, "no thanks - we need buttons" to which Apple replied "the crown is a multi function button that can control behaviors of an application." Silence after that.
                              • GMLIII
                                • May 2013
                                • 2821
                                #225
                                pitts12driver
                                My Pebble works just great and Garmin does too fine with model years after my MY 17 . Screw Apple Watch Ain’t never going to work . Press on with what you got .
