Winterizing
  • Lakewoodwater
    • Oct 2017
    • 23
    • Lakewood wa
    Winterizing
    I have a 2017 gs22 with a boat lift and a canopy and am leaving it on the lift this winter. I have heaters in the engine compartment. Does anyone have any winterizing advice or things they do on there nautique? Does anyone have any reviews on these skirts https://www.nautiqueparts.com/produc...-cover-skirts/ or any other skirts that have worked for you? Thank you!
  • GMLIII
    • May 2013
    • 2807
    Im leaving my G23 on my lift all winter as well. Im winterizing mine therefore no heaters needed. On the skirts although Nautique Parts has them , I purchased my stern skirt from BoatCoversDirect in Sunbrella material and I'm very pleased with it. They also have side skirts as well. I think Boatcoversdirect will have more fabric choices and colors than offered from Nautique Parts. Both companies provide a 10% discount to Planet Nautique members.
    • Lakewoodwater
      • Oct 2017
      • 23
      • Lakewood wa
      Thank you so much!
      • Lakewoodwater
        • Oct 2017
        • 23
        • Lakewood wa
        Also what do you do to winterize
        • Nautiquehunter
          • Jun 2008
          • 2091
          The heaters work great as long as the power doesn't go out or it gets unplugged somehow. Read the post RV Antifreeze or Not. Check with your insurance company and make sure you have freeze coverage.
          • GMLIII
            • May 2013
            • 2807
            Im going to get my dealer to winterize but if you plan to winterize yourself there are drain plugs to remove as stated n your manual . Once they are removed along with emptying your water strainer you should be fine. If you have a heater in your boat that will need to drained as well
