G Series Draft Specs
  • nohlan_4
    • Jan 2016
    • 420
    • Canada
    • 2013 G23 450
    Draft is correct. Has to do with the shape of the hull. 230 is almost a deeper V shape.
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      Isn't the G3 wider? If so, that would make it more bouyant and therefor less draft
      • thejean
        • Aug 2017
        • 364
        • Calgary, AB
        Yes G23 is 2" wider so that's a good point. But it's also 1250 lbs heavier, which I think would more than make up for that. But likely the V bottom is the major difference.
        • monkeybutt
          • Dec 2017
          • 3
          • Minneapolis
          • other
          has somebody actually measured it? I always thought that the G23/G25 would be prohibitive for me - but that was from a mere looks perspective. So despite the 17" prop for a 2017 (plus an " clearance - the prop as lowest point is only 25" below the water line?
          • thejean
            • Aug 2017
            • 364
            • Calgary, AB
            Yep, that’s my understanding but to your first question, I have not actually measured it myself.
            • monkeybutt
              • Dec 2017
              • 3
              • Minneapolis
              • other
              #21
              Well if there is someone where winter hasn’t hit yet
              lake i live on has a channel which is a PITA when water levels are low. Banged a rudder 3 years ago with subsequent hull repair ... last season a prop with a 23 LSV. So looking at a new boat and always thought that the G will not work until I finally looked up specs. The pics are revealing a lot - the Malibu is definitely sitting lower in the water than the G but I’m still surprised that the G would be 3 inches less ... so if someone could once measure it? To be honest - based on the licstures shown - there’s little doubt that the hull would be 2ft lower than the waterline on an empty (fuel?) boat ...
              • nohlan_4
                • Jan 2016
                • 420
                • Canada
                • 2013 G23 450
                #22
                My boat floats easily in 3ft of water (measured) with full fuel, gear and 1300lbs of ballast full in the back lockers so I would say the draft measure would be close with full fuel and gear minus the 1300lbs of ballast.
