Surfing from Northern Alberta
  • GMLIII
    • May 2013
    • 2821
    #31
    Ok I will try NSS at 2-3 and move the 150 lbs of lead on port bow to port locker and move the 150 lbs on port pull-out bench seat to starboard locker and keep the 200 lbs under port observer seat alone. Also to note NSS on the 2017 G23 max is at 0 and not 5 but I don't know if that was the case on the 2013 G23. Thanks for your help on this
    • nohlan_4
      • Jan 2016
      • 420
      • Canada
      • 2013 G23 450
      #32
      If your referring to max as in maximum extension of the plate then yes it's the always been the same. 0 extends the plate maximum but in reality it dumbs down the wave by making the water converge further behind the boat. 0 on nss creates the most drag of that makes sense.
      • GMLIII
        • May 2013
        • 2821
        #33
        Thanks again. Your response makes sense.
        • surfnjosh
          • Jul 2016
          • 104
          • Canada
          • 2021 G23 2020 G23 2017 G23 2013 G23 2012 230 Team
          #34
          Maybe somewhat but even my 58 inch Phase 5 Ahi struggled at the 12.5 mph speed. The 60 inch noted above was a Liquid Force Keen
          Well a liquid force KEEN is a skim style board so that's just too fast for skim anyways. Nolan is surf style along with the HC pro he rides. I ride HC pro too for surf and just so happen to ride the KEEN for skim. I ride the 52" keen and honestly it's a bit of a slow board, but I love it now for skim. Im around 175
          • GMLIII
            • May 2013
            • 2821
            #35
            Yeah I messed around with both boards at that 12.5 speed and both struggled to hold the push . Keen and Phase 5 Ahi .
            The Ahi was a Surf style board and still struggled. I need to tweak my shot bags as Nolan suggested to even the boat out more . I had 500 lbs of shot on port side with all ballasts filled which made boat unbalanced to port side
