2007 - 2010 236/230 set up for surfing?
  • shag
    • 2217
    Just like it says, whats the best way to set up this boat to surf? I have a 08' 230 with factory tanks and sacks plumbed on top. Center arrow sack plumbed and maybe 300 pounds of lead I can move around. I have an aftermarket NSS type system and the wake is decent, but trying to make it a little better and longer..
  • DeanT
    • Jan 2017
    • 44
    • Vancouver,BC
    • 2016 G25 XR550
    I had that same boat and so did my cousin. The arrow sack never worked nearly as well as the under cushion U sack(below along with the other sacs). The very best wake was a 1100 in the rear locker side you want to lean, 750 under the front cushions (or until the seats popped up and you will need to bleed the air) and a half full bow sac. Also we would put the large L shaped sac on the side you were leaning. If you do all that you will have the best wake going between 10.6 and 11.2 MPH. Just be careful on the corners or rough water because the engine intake gets very close to the water line.
    The Pro X Series Open Bow Sac is triangular in shape and fits open bow boats. Just set it up front and fill it. The size of this sac allows you to fine-tune the forward and aft weight distribution. Chances are that this is the only sac you will need up front.
    Avaliable In:
    New: Now avaliable in CAMO!
    Pro X Series Open Bow Sac - W706 / W706-CAMO
    DIMENSIONS: 54 x 54 x 54 x 12 WEIGHT: 1000 lbs. / 454 kg.
    Pro X Series Integrated Bow Sac - W711 / W711-CAMO
    DIMENSIONS: body- 20 x 29 x 12 arms- 32 x 12 x 12 WEIGHT: 725 lbs. / 329 kg.
    The Pro X Series Integrated Bow Sac is designed to fit under the seats of open bow boats adding needed weight to the front of the boat for the perfect weight distribution. It will fit under the seats of any open bow boat so it’s out of the way and the seats are still available for use.
    CLICK HERE TO SEE IT IN A V-DRIVE BOAT
    Avaliable In:
    After filling any factory ballast and FatSac that fill the front and rear compartments of your V-drive boat, put the Ultimate Wake Surf Sac on top of the rear seat and side seat that you are wake surfing on for the ultimate surf wake. This will displace so much water that people will no longer have to learn to wake surf behind your boat they will just be able to do it. Be sure to remeber to give the boat some throttle to bring the front of your boat up enough when passing thru any wakes you are making so you dont swamp the boat. Will also conform to fit in other type boats and in other places.
    IMPORTANT NOTE: HOLD THIS SAC UP ON THE SEATS WHEN FILLING & EMPTYING IT SO IT WILL NOT ROLL OFF, BUT WHEN IT IS FULL IT CANNOT ROLL OFF BECAUSE OF ITS L SHAPE.
    Avaliable In:
    Pro X Series Ultimate Wake Surf Sac - W718 / W718-CAMO
    DIMENSIONS: body- 60 x 24 x 16 arm- 35 x 12 x 16 WEIGHT: 1150 lbs. / 520 kg.
    • shag
      • 2217
      So it likes more weight up front I guess.
      • max 1.6
        • Oct 2014
        • 287
        • Canada
        • 2009 Nautique 230
        River or lake?
        You want it bigger or longer?
        What's your prop?
        • DeanT
          • Jan 2017
          • 44
          • Vancouver,BC
          • 2016 G25 XR550
          It needs more in the front because of all the weight in the back, seems like it needs to be sunk down evenly.
          • chris9304
            • Jan 2014
            • 12
            • orlando
            i have an 07 236 with 1100's in the rear and the arrow bow sac plumbed into the belly overflow. i have a mission surf gate and have had some awesome waves. this weekend i had 7 people in the boat the wave was the best it has ever been.
            • Dave Rittiman
              • Apr 2013
              • 209
              • Nor Cal
              • 2009 Nautique 230 Sold 2016 Supra SE450
              If you have a 2007 - 2009 230 you should have ski locker and can do the locker bag it works great.
              Fly High Pro X Series Nautique Center Locker Sac (650 lbs)
              https://www.wakemakers.com/nautique-...ocker-sac.html
              Rear use the 1100's
              Fly High Pro X Series Jumbo V-Drive Surf Sac (1100 lbs)
              https://www.wakemakers.com/fly-high-jumbo-surf-sac.html
              WakeMAKERS Engine Divider Panel Saver
              https://www.wakemakers.com/engine-di...nel-saver.html
