Our 2017 G23 will be here in a few weeks and we can't wait to take it out. We've never owned a Nautique and have also never done anything other than "stock" in terms of weighting on a boat. From what I've read, it seems like a good idea to weight the G23 a little heavier on the port side to offset the prop rotation. We mostly use our boat for surfing and beginner wake boarding at this point. It's usually just my wife and two little ones, so not a lot of passenger weight.
So would you recommend doing something in terms of a more "permanent" solution like leadwake.com bags -- or just adjust the ballast to be a little heavier on that side each time? If we put the 50 lb bags in, where would you locate them? Are there any concerns about damaging the boat if you go over rough water and caused them to go flying or are they way too heavy for that? Any other suggestions for setting it up right?
Thank you!
Thank you!
