SV211 wake shaper
  • sfjakey
    • May 2005
    • 208
    • SF Bay Area
    • 2015 230 ZR6
    SV211 wake shaper
    Like the title says, has anybody successfully used one of these wakeshaper devices on a SV 211? If so which model worked, what didn't and how did it change the surf wake. Thanks for the input.
  • cjacob06
    • Jul 2010
    • 31
    Heres a short clip of my 2005 sv211 with the homemade suckgate. I built it to similar dimensions as the Mission delta and have the plate offset by 20 degrees. This was the first dry run with zero ballast and 4 adults on the boat. Prior to using it, the regular footed side was all prop wash and pretty much un-surfable without serious weight and listing due to the prop rotation. The suckgate cleaned it up incredibly well.
    • pokesgrad02
      • Aug 2012
      • 170
      • Lenexa
      • 2018 SAN 230
      Build a suck gate. Changed my life since my wife is regular foot and I am goofy. Not having redistribute weight when we switch riders is awesome. Just switch the suck gate, duct tape your hull vent closed on that side and ride.
      • pokesgrad02
        • Aug 2012
        • 170
        • Lenexa
        • 2018 SAN 230
        https://vimeo.com/177783499
        350 in the ski locker 1650 in the back evenly filled port and starboard. Holding the rope to give a sense of how far back you can surf. This board was a little short for me so I had to play catch up a lot. Definitely a much better wake with the suck gate than without. Mine is 90 degree 9x11 face if memory serves me correctly. Been using all summer and has never came off. Will post a pic of it too
        • pokesgrad02
          • Aug 2012
          • 170
          • Lenexa
          • 2018 SAN 230
          • homer12
            • Feb 2016
            • 584
            • Indianapolis, IN
            • 2004 SV211 TE
            I need to do this too. Anyone have a pic or describe where they stick it on your hull? And is that right - you have 1650lbs in the back of your 211?!
            • Fast351
              • Oct 2006
              • 315
              • Winsted, MN
              • 2001 Ski Nautique
              Seriously considering buying the Swell Wakesurf Creator. ( http://www.swellwake.com/ )
              Currently run this setup in my '07:
              Belly tank full (330#)
              Starboard tank full (200#)
              Fatsac in walkthough (440#)
              Total of 970#
              It's entirely surfable with a couple people besides the driver sitting on port side by a fairly large person. The wake's not super long (you can probably ride comfortably up to about 10' back from the boat)
              With the suckgate, I should be able to run all stock ballast (730#) and then my Fatsac somewhere in the boat for a total of 1170#.
              It should produce a nice improvement.
              Anyone done it?
              2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
              • homer12
                • Feb 2016
                • 584
                • Indianapolis, IN
                • 2004 SV211 TE
                Fast351, what speed are you running and where do you put the hydro gate?
                • Fast351
                  • Oct 2006
                  • 315
                  • Winsted, MN
                  • 2001 Ski Nautique
                  Hydrogate is on slalom (yeah I know it sounds weird, but I played with it to get it perfect).
                  Speed is 9.8 to 10.3 depending on amount of weight in the boat.
                  • Woody_tobius_jr
                    • Dec 2012
                    • 248
                    • Alberta, Canada
                    • 2004 SV211 Air Nautique TE
                    I got to try my QSWS adjustable wake shaper yesterday, and what huge difference! I have an '04 211 with the opposite prop rotation. I could never get a wake to surf on without holding onto the rope. I tried all three positions on the wake shaper and found that the middle position was best at 10.5 mph. No extra sacs. I tried one extra in the front walk through, but I really didn't need it. Picture below has no extra sacs. My daughter could surf behind it all day with no rope, sweet spot was about 6-7' off the swim grid. She could go back about 10' and still come back. Best mod so far for my boat 👍🏻 😊
                    • homer12
                      • Feb 2016
                      • 584
                      • Indianapolis, IN
                      • 2004 SV211 TE
                      Wow Woody, nice! Did you have factory tanks full? Do you have any pics where you placed on the hull?
                      • Woody_tobius_jr
                        • Dec 2012
                        • 248
                        • Alberta, Canada
                        That was just factory tanks, I had already drained the front walk through bag when I took this photo. Positives - Boat not listing, intake vents not taking on water, no, spending time filling / draining extra bags, I really have nothing negative to say about this product 🙂
                        • homer12
                          • Feb 2016
                          • 584
                          • Indianapolis, IN
                          • 2004 SV211 TE
                          Well, here is what I came up with for a Suck Gate and placement on hull, as well as the wake I was producing. Water was a little rough making a good clean pic kind of hard. Click image for larger version
ID:	498789 Specs are '04SV211, 9.8mph, factory ballast only, Hydrogate in slalom mode. I think I need to get it farther back on hull, but I'm curious to where other people are getting it to stay on an SV211.
ID:	498787 Click image for larger version
                          • Super B
                            • 92
                            • Twin Cities, MN
                            • '09 SV 211-Current '85 2001-Sold '78 Ski Tique-Sold
                            I have a '09 with 1100lb bags on each side. Pic here I have the bags about 80% full. Belly ballast full with a homemade suck gate. Speed is 10.6.
                            '09 SV211
                            '01 Tige` 21i
                            '85 SN 2001
                            '78 Ski Tique
                            • dwelsh
                              • Oct 2011
                              • 35
                              • Australia
                              • 2004 SV-211
                              I just finished making my home made suck gate for my 211 but haven't tried it as yet. I can't wait to give it a go, from all reports it appears to clean the wake up considerably. Mine is set at 60 degrees and the plate is approx 8' x 9' in size. I currently have the factory hard tanks but have purchased rear wedge sacs that sit on top of factory rear hard tanks, a bow sac and another sac to go under the love set. I was going to make a manifold with a single Jabsco pump to fill and empty the sacs individually but after seeing this post I wonder if its actually going to be worth the extra effort. Am also considering installing an FAE.
