Lately the LINC always says my port bag is full when I power up the boat. The pump fills and empties fine and the boat is on a lift so I know it is empty. Unplugged the ballast sensor, replaced the 1 amp fuse, cycled the power, same result. Bad sensor? Anyone else had similar issues?
I replaced mine under warranty and work fine after false readings2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
I am having the exact same issue on my 2013 G23. Every time I power the boat on, the Port ballast shows full. Works and reads just fine once you let the pump run on drain for a few minutes. Interested to see if we can get any DIY help that doesn't require taking it to the dealership. Thanks
Wilson Watersports? Lol2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
