Been watching this site for a while, learned a lot so far, hoping someone out there has done this before and could save me some trial and error. I have a '04 206 w/ the Excal 330. I live in the UP of Michigan so many of my days on the water are cold and the season is already short. Hoping to extend with a shower to warm up wetsuits and toes. Trying to locate the proper place to tie in the HW and CW leads. I have attached some photos to try to guess where these go. Boat has a factory heater which I believe uses the red hose in the top two photos coming off the front left side of the motor for the HW supply as it comes out of the top of the block. Guessing I can remove the "plug" in the brass fitting my daughter was kind enough to point to, and get hot water there for the shower. The bottom photo comes off the fresh water pump into a "mixing" area that appears to then send water to the manifolds and down lower on the motor. I'm guessing I'd "T" into this for the CW supply.
Lastly, using a pump from the kit can I just tie the wires into the keyless ignition dash panel and use the factory "shower" switch? I'm assuming there should be power to the panel already and I'd just have to connect the wires to the proper location to use the switch to control the pump for the shower that way….at least I'm hoping.
Thanks in advance for any input and if anyone has photos of an install they did or best place to source parts it would be much appreciated.
