Just looking for thoughts on how to wire a switch. Adding LEDs as courtesy lights in the boat. How did you do it? Wire in a separate switch or wire to existing light switch?
I would suggest using the existing courtesy light switch on the keypad. That switch has two functions. Hold it down to turn on the docking lights, or press and release quickly to turn on the courtesy lights.
Alternately, you could use the 12-Volt switch that is not used for anything from the factory.
Yes use existing buttons if possible. I replaced those crappy courtesy lights in my 03 SANTE with LED strips. Just cut the factory light wires at the light and soldered, splice on extension wires, and then soldered the extension wires straight to the LED strips. Factory button controls it no problem.
ok, I was wondering in by doing so the LED got annoying and anyone isolated them to another switch. I will leave on the existing for now.
I am refinishing a boat and opted not to put back in the heater as I will never use it, and it was rather expensive for a part that would likely need replaced before someone actually used it. I put it led cupholders, blue lights in the vents, and seablaze x's out back. I ran the cupholders to the first press on the heater switch (low), the seablaze x's and vent lights to the second press (medium), and all three to the third (high).
