trailer swap. 2001 - 210 SSN to 2005 206 air.
  • brettmcox
    • Jan 2007
    • 284
    • Unknown
    wanted to see if anyone could give me some input on a trailer swap on a 2001 210 to a 2005 206.
    I ask because i am looking at a 206 but the trailer will not work because it is an A-frame at the front, thus it can not be removed.
    I have the standard late 90s early 2000 Ram-Lin with the bow catch that can be moved to fit a SSN/SAN or a SKI/Sport.
    thanks for any input.
    2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
  • TRBenj
    • May 2005
    • 1682
    • NWCT
    I have never seen a ramlin that could be adjusted to accommodate either a direct drive or a v-drive. I believe they are/were only adjustable to accommodate different length boats with the same powertrain layout. V-drive vs direct drive will usually dictate a significant difference in axle placement.
    1990 Ski Nautique
    NWCT
    • brettmcox
      • Jan 2007
      • 284
      • Unknown
      I am sure the 18 to 24 inch adjustment for the bow stop will work for the wight shift from Back to Mid ship.
      I root questions is will a 206 work well with just the FLAT side boards and ONLY those. NO center catch that keep it in the middle, no bow V below NEAR window line on the trailer.
      Just the PLAN BLACK TRAILER with PLAN FLAT 18 foot Carpet, wood, and just 3 by 1 foot bow stops.
      • TRBenj
        • May 2005
        • 1682
        • NWCT
        18-24" of Bowstop adjustment is extreme. The dd ramlins I have seen did not have that much adjustability. I am curious how such a trailer would accommodate 2 different ~21' boats with vastly different COG's... 18-24" of Bowstop movement would be needed to keep the tongue weight in check- does one configuration have the boat hanging 2' beyond the bunks? I haven't seen a cc trailer set up this way since MY 1983. Or is there 2' of extra bunk extending past the stern of a V-drive? Seems the prop guard wouldn't be much use.
        Something doesn't add up. Id be amazed if the dd and vd trailers are interchangeable.
        1990 Ski Nautique
        NWCT
        • brettmcox
          • Jan 2007
          • 284
          • Unknown
          I found this, and this is my same setup...
          http://www.wakeworld.com/MB/Discus/m...tml?1266357512
          But it looks like this one is LONGER behind the wheels (IE giving rear protection)
          http://boatsforsale.internetrader.co..._________.html
          So it makes me think they will not match up prefect. but they KIND of will work.... (not correcly)
          AND this,,,
          http://www.correctcraftfan.com/diari...rt=&pagenum=65
          • TRBenj
            • May 2005
            • 1682
            • NWCT
            The first trailer is a Prestige, not a ramlin. I'm not sure what you are seeing in those pictures that proves a point either way. The v-drive and direct drive trailers look similar but have very different axle placement due to the rearward weight bias of the v-drive.
            Some direct drive trailers were adjustable to accommodate different length boats (196/206, for example). Depending on tongue/bowstop set up, it is normal to see the bunks with 3" or so of the transom in either direction.
            1990 Ski Nautique
            NWCT
            • NCH2oSki
              • 1159
              • Maryville, TN
              • 2005 ski nautique 206 SE
              The trailer for the older V drive will not tow well with the 206 on it. I would think it will have a lot of tongue weight, since the axle will be well behind the motor. I think the 206 hull will probably sit on the wishbone trailer fine, but towing will be the issue.
              Could you have the 206 trailer fitted with a swing away coupler? http://www.etrailer.com/Trailer-Coup...DPW330300.html
              Prior Boats:
              1999 Ski Nautique GT-40
              www.skiersofknoxville.org
              • brettmcox
                • Jan 2007
                • 284
                • Unknown
                The trailer on the 206 is one with a HUGE A out the front. I would have to take it to a welding shot have have the frount cut off, and tweet a few things to get to fit in my 21 foot garage.
                I know my SSN 210 should just about fit and i might have swing it around a little, but this a new home so i will have to wait to see that the space is like....
                LOVE my current 26 foot deep garage..... HATE the floor plan of the home.
                • TRBenj
                  • May 2005
                  • 1682
                  • NWCT
                  I'm still not following you, Brett... Which 206 trailer are you referring to?
                  1990 Ski Nautique
                  NWCT
                  • brettmcox
                    • Jan 2007
                    • 284
                    • Unknown
                    http://www.boattrader.com/listing/20...Team-102132801
                    • TRBenj
                      • May 2005
                      • 1682
                      • NWCT
                      The 206 on the magnum trailer? What's that have to do with the price of tea in China?
                      1990 Ski Nautique
                      NWCT
                      • brettmcox
                        • Jan 2007
                        • 284
                        • Unknown
                        that is the boat i was thinking about getting, and trading the trailers. Because of the tongue on that trailer being a Huge A at the front it will not work for the garage that i want to put it in. I was thinking that If i could swap trailer. (also newer, better for skiing and a few other details). I cannot swing for a SPORT200 at this time
                        • TRBenj
                          • May 2005
                          • 1682
                          • NWCT
                          Now I'm following. Yes, that trailer would be a pain. It would be longer than necessary without a swing tongue, but I bet it would fit in a 26' deep garage with the platform removed. I have a 19' bfn in a 23.5' deep (inside) and it just barely fits. It predates the swing tongue and the platform isn't removable, so I bet it's roughly the same length as a 206 would be.
                          Either way, I would not count on a trailer swap with your SAN working out for either party.
                          1990 Ski Nautique
                          NWCT
                          • NCH2oSki
                            • 1159
                            • Maryville, TN
                            Why dont you just buy my 206, it allready has the swing tongue on the trailer. $30,000.
                            Prior Boats:
                            • jmo
                              • Mar 2006
                              • 710
                              • MA
                              For me, I want to make sure my baby is well taken care both off and on the water, so when I bought my 196 (used and didn't have a trailer) I just bought a new one for it to ensure I have piece of mind. Getting a trailer that wasn't designed for the boat would worry me. It's like another 10-15% more in cost, isn't "the other woman" in your life worth it?
                              JMO
                              2018 Ski Nautique 200 TE, H6
