Chevy Tahoe good tow vehicle for G21
  • Ninja
    • Feb 2015
    • 41
    • Knoxville
    • Malibu
    With trailer and gear included?
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    It'll be at the limit 7500-8000lbs range. A loaded G23 is 8-9000lbs with the trailer.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • Ninja
      • Feb 2015
      • 41
      • Knoxville
      • Malibu
      G21 dry weight is 5200 lbs, you are adding an additional 2000 - 3000 lbs?
      • JamesHawk101
        • Dec 2012
        • 224
        • Indian Rocks Beach
        • 2015 G23 Coastal
        We tow are G23 with a GMC Denali Yukon XL. Pulls it fine and is under limit
        2015 G23 Coastal Edition 450 NSS
        2013 G23 Coastal Edition 450 NSS
        • Ninja
          • Feb 2015
          • 41
          • Knoxville
          • Malibu
          Well test drive a nice Tahoe today and the salesman made a mistake on towing capacity. At first he said 8600 lbs then he said 5200 lbs because it had the wrong tranny. Too bad, it was a nice Tahoe.
          • JoeA
            • Jun 2014
            • 808
            • Chickamauga Lake TN
            • 2015 G23 550
            Ninja--
            Not sure what year Tahoe you were looking at however it looks like a 2007 Tahoe can tow up to 8,500 lbs.
            http://www.autotrader.com/research/a...-for-20000.jsp
            2015 G23 550
            2013 Malibu 22MXZ
            • swatguy
              • 1646
              • Midwest/ Northern IL
              • 2008 SANTE 210
              The gearing and tow package really matter on the tow capacity. You don't want anything with the standard 3.08 gearing. It's awful.
              How far are you towing and what is the terrain like? That will be more of a deciding factor. The Tahoe can handle the G21. It just needs to be equipped correctly. At minimal you'll want 3.73 gears. But best would be the 4.08. What year Tahoe are you looking at? There was a huge transmission change and that also plays a huge factor. 07-08 was the 4 speed. Absolutely garbage for any long distance towing. 09 got the 6 speed. Much better.
              I would swap over to the Yukon and go Denali with the 6.0l engine. Will give you the added umff over the Tahoe.
              • swatguy
                • 1646
                • 2008 SANTE 210
                Dry weight. Add at least another 2000 for the trailer, gas, fluids, gear and kids.
                • Ninja
                  • Feb 2015
                  • 41
                  • Knoxville
                  • Malibu
                  My wife has got to drive this car. Going to a suburban may be too big. The 3.08 tranny on the Tahoe has a capacity of only 5200 lbs. The 3.52 tranny I think goes to 8600 lbs.
                  Adding an additional 2000 lbs to the G21's dry weight is a bit much, IMO
                  • nyryan2001
                    • Mar 2013
                    • 1993
                    • Lake Anna
                    Afun, at least 2000. 2500 would be more accurate, fully loaded up and Heading to the lake. Dry weight is not a single option, not a single drop of any fluid, no gear, trailer and the smallest engine.
                    Guys who have ran their G23s over scales have shown 8-8300lbs. Mine with a big stereo and regular gear is 8800 range. That is not counting the 300lbs lead I also keep during the season in there. What a couple hundred pounds difference between a G21 and G23?
                    2019 G23 450
                    2014 G23 550
                    2013 G23 450
                    2007 Yamaha AR210
                    • nauty220
                      • Apr 2008
                      • 230
                      • Friendswood TX
                      I used to tow my g23 with a 2012 Yukon Denali. Although it has more power it sure drank the gas at 7mpg on the hwy.
                      2014 G23 450 Coastal Edition
                      2013 G23 450 Coastal Edition
                      2010 SANTE 230
                      2007 SANTE 220
                      2003 SANTE 210
                      • nyryan2001
                        • Mar 2013
                        • 1993
                        • Lake Anna
                        Mine weighs 9300ish range with the additional weight of the triple axel and 8" tube frame
                        and the lead I keep in there in the summer.
                        The Tundra tows it fairly well, drinks 7mpg at 70mph on flat ground.
                        2019 G23 450
                        2014 G23 550
                        2013 G23 450
                        2007 Yamaha AR210
                        • swankster
                          • Aug 2010
                          • 1052
                          • DFW, TX
                          I hooked mine up to my wife's and it is unbelievable how small the GMC Denali Yukon XL looks with the G23 behind it. But it will pull it.
                          2010 SANTE 230 343 (280hrs)
                          • JamesHawk101
                            • Dec 2012
                            • 224
                            • 2015 G23 Coastal
                            Oh my god I know it looks so tiny. We towed ours all the way from Tampa, FL to Lake Keowee in SC without a problem though. Transmission did get a little hot if we hit 70mph though.
                            • Ninja
                              • Feb 2015
                              • 41
                              • Knoxville
                              • Malibu
                              Untitled by Afun2011, on Flickr
                              I bought this vehicle. 2003 Chevy Silverado SS AWD 6.0.....its mint and so much fun....
