2013 g changing gear ratio
  • chrisschweda
    • Sep 2010
    • 140
    • New Orleans
    • 2015 G23
    Has anyone changed the gears on the 2013 g23 to the 2:1 like the 2014 I have heard it is way more efficient and would love to do it I could do the work myself.
  • swankster
    • Aug 2010
    • 1052
    • DFW, TX
    I had it quoted and the quick estimate I got was $5k installed with the propeller being about $1k of that.
    2010 SANTE 230 343 (280hrs)
    • chrisschweda
      • Sep 2010
      • 140
      • New Orleans
      • 2015 G23
      Was that a new trans or gear change I sure I can change the gears yet I understand the shaft is larger as well yet I wonder if I could keep the same one.
      • Devodad
        • Jan 2014
        • 13
        • Minnesota
        • 2018 G23 H6 2013 G23 450 2006 Mastercraft X 45
        I also have a 2013 G23 with a 450. I re-propped it last fall to a 2419. Probably won't be anymore efficient but I think the hole shot is supposed to be better. I Iike the idea of switching the gear ratio to 2:1.
        • chrisschweda
          • Sep 2010
          • 140
          • New Orleans
          • 2015 G23
          My concern is with full ballast and boat full of people and it does not want to get up and I would prefer it to be more efficient.
          • swankster
            • Aug 2010
            • 1052
            • DFW, TX
            I'm not sure how they were going to do it, but I'll find out. I had a new 2014 at the dealer ready to make the swap but my 2013 didn't sell and I could not do the swap without it selling it first. I could handle the one year model upgrade price difference but cannot swing the two year upgrade to a 2015. So now I'm in the position of trying to upgrade my 2013. I'm not sure I could handle doing it myself, so I'm having to use the dealer. My biggest worry on the self install would be changing the shaft and keeping it aligned. A big part of the upgrade is the bigger prop which requires the bigger shaft.
            • vision
              • 530
              • NC
              • 2013 G23
              Certainly the 2:1 with larger prop improves hole shot when heavily ballasted. But does anyone have rpm data at speed or GPH data? I suspect that fuel efficiency goes down unless the larger prop transfer energy much better than the smaller prop.
              • xrichard
                • Aug 2008
                • 671
                • El Dorado Hills
                • 2023 G23
                It'd be interesting to see real world data. My guess is your efficiency while wakeboarding will go up because you spend less time climbing out of the hole--which is where you suck a lot of gas. For cruising, my guess is you lose a little mileage.
                Previous boats:
                2015 G23
                2008 SAN 210
                2002 XStar
                1995 Sport Nautique
                • nyryan2001
                  • Mar 2013
                  • 1993
                  • Lake Anna
                  Absolutely not. Your boat is 18secs 0-23 with full ballast. Put a 2315 on there is 13secs 0-23mph full ballast.
                  2019 G23 450
                  2014 G23 550
                  2013 G23 450
                  2011 Malibu Wakesetter 247
                  2007 Yamaha AR210
                  • nyryan2001
                    • Mar 2013
                    • 1993
                    • Lake Anna
                    Roughly 9-10secs for A 450 2:1 on 17" prop 0-23 with full ballast. 550 is 7-8secs.
                    2019 G23 450
                    2014 G23 550
                    2013 G23 450
                    2007 Yamaha AR210
                    • Tallredrider
                      • Oct 2014
                      • 1026
                      • St. George, Utah
                      The dealer who wanted to sell me a new boat is a user as well and gets a new boat each year. He said his fuel bill went down by about 40% with the new tranny/prop combo. Using the boat in the same way as before. Of course, that is coming from a guy asking me to spend 6 figures on his product, but I currently believe him to be an honest guy.
                      Looks like NYRyan has found a huge benefit in hole shot, I would expect fuel economy as well.
