"N" led hitch cover
  • Mikeski
    • 2908
    • San Francisco, CA
    "N" led hitch cover
    It's raining outside, I can't work on my boat so I decided to make a new hitch cover for my truck. Check it out.
  • Mikeski
    • 2908
    • San Francisco, CA
    After I laid out the hole spacing I drilled a think piece of plex as a jig
    • Mikeski
      • 2908
      • San Francisco, CA
      Here are the little LEDs, these are cheapies, not the good clear bright ones.
      • Mikeski
        • 2908
        • San Francisco, CA
        Here is the plate after the holes were drilled
        • Mikeski
          • 2908
          • San Francisco, CA
          Back of the plate
          • Mikeski
            • 2908
            • San Francisco, CA
            Next the LEDs were glued into the plastic plate
            • Mikeski
              • 2908
              • San Francisco, CA
              Here is what the front of the plate looks like with the LEDs off. The plate is supposed to look like carbon fiber.
              • Mikeski
                • 2908
                • San Francisco, CA
                It took a bit of time soldering all of the LEDs up. I ended up with an odd count so I had to add a resistor into the equation.
                • Mikeski
                  • 2908
                  • San Francisco, CA
                  Here is what it looks like all lit up. Now I have to fill the back with resin and attach the hitch insert.
                  • radmaster
                    • May 2005
                    • 76
                    Thats Sick, are you going to wire it up so that it comes on with your brakes?
                    • Mikeski
                      • 2908
                      • San Francisco, CA
                      I was planning on hooking it to the tail lights but I can probably hook it to the brakes too if I add another diode.
                      • M3Fan
                        • 1034
                        I think you'd almost have to wire it up with the brakes only. It seems like having any bright red light in the centerline of the vehicle might be misleading to other drivers if it wasn't wired to brakes only. I think all the storebought lighted hitch covers only illuminate during braking for that reason, but I could be wrong.
                        2000 Ski Nautique GT-40
                        2016 SN 200 H5
                        www.Fifteenoff.com
                        • surroundsound64
                          • Jul 2005
                          • 2148
                          • Longview, TX
                          • 2026 S23 1981 Ski Nautique
                          How much? Yellow_Flash_Colorz:
                          2018 SAN 230
                          1981 Ski Nautique
                          Sold - 2011 Sport 200V
                          Sold - 2000 SAN
                          • AbunDiga909
                            • Sep 2003
                            • 2470
                            • St. Louis, MO
                            Nice job Mike! Looks awesome...
                            • Socbum
                              • Oct 2003
                              • 268
                              • Columbus, Ohio
                              • 2002 210 Super Air Nautique Previous 1987 America
                              Very nice! It must have been raining for a long time.
                              Are you going to take the wires and connect them into a plug that would go into trailer light plug?
                              SocBum
                              2002 SAN <== Current Boat
                              1987 American Skier Advance <==First Boat
