Ski Locker and Phat Sac
  • Molly_2000SAN
    • Mar 2005
    • 20
    • Minneapolis, MN
    I can't find the post I saw the other day, but does anyone know the phat sac I should use for my ski locker on the 2000 SAN. I want to load it down for surfing.
    Does anyone here have problems with the ski locker taking in water? Also I've noticed my carpet to be wet by the drivers seat but can't tell where the water is coming from - does this indicate a crack somewhere?
    • 16761
    • 2026 SAN G23 PNE 1985 Sea Nautique 1980 Twin-Engine Fish Nautique
    Re: Ski Locker and Phat Sac
    Does your boat have a heater? If so, your heater core might be cracked. Is the water hot?
    • Molly_2000SAN
      • Mar 2005
      • 20
      • Minneapolis, MN
      RE: Re: Ski Locker and Phat Sac
      I have a heater but I don't use it much - does that matter? Are you referring to the water by the seat or the ski locker - I assume the seat? My boat is up north at the cabin but I will take pictures next time I am up at the boat and post them to the site.
      • jhiestand
        • 783
        • Columbus, Ohio
        • 08 Super Air 210
        Water circulates through your heater core regardless of whether you use your heater or not. You probably have sprung a leak, there. I wouldn't be suprised if that water is making the area by your seat wet, plus making it down into your ski locker.
        I've heard of some folks using the Skylon Locker Sack (http://www.wakeside.com/page/W/PROD/...on_locker_sack). I had a custom bag done by LetsGoRide but I don't think they're in business any longer.
        '08 Super Air Nautique 210
        • Molly_2000SAN
          • Mar 2005
          • 20
          • Minneapolis, MN
          Thank you jhiestand - how would I go about checking for the leak? Is this something I can do myself or do I have to have a dealer look at it?
          Thank you for the info on the locker sack.
          Molly
          • jhiestand
            • 783
            • Columbus, Ohio
            • 08 Super Air 210
            Usually the heater is located behind the driver footwell kick panel. The only way I'd know to troubleshoot it or check for leaks is to remove the kick panel, then visually inspect the heater while the boat is running. It might be leaking in the back where the water goes in/out, or if there is a leak in the core itself you probably will see water coming out of a corner of the heaterbox.
            You can see what the heater core looks like on the Heatercraft web page (http://www.heatercraft.com/).
            If you're not very handy, I'm sure your dealer could check it out for you. Hope this helps!
            • Molly_2000SAN
              • Mar 2005
              • 20
              • Minneapolis, MN
              Thanks for the info - I'll check that out.
              I'm not very handy but have plenty of guy friends who are :grin:
              • wakefun
                • Aug 2003
                • 81
                • Oregon
                Molly -
                I own a 2000 SAN and the heater core let go in mine last year. (Took me forever to figure out why the carpet around the drivers feet was all soggy and warm...) I had the dealer fix - don't remember what the cost was, however.
                Regarding the locker sac - we use the skylon version mentioned above by jhistand. It fills in the space nicely and really improves the wake when used in conjunction with the factory ballast.
                • Alan-S
                  • Nov 2004
                  • 161
                  • Richmond, VA
                  Molly, I have tried several sacs in my old '01 SAN and the very best one is the
                  Pro X Series Rear Seat Bottom Sac. The dimensions are 12" x 26" x 62". If you measure your locker you will notice that they are the exact same dimensions. This sac is very very thick and has the quick disconnects that work with any pump. I have had the Skylon and the Launchpad sacs tear on me, this one will not tear. It is also very rectangular so it does not twist at all, it will fill and empty and never move. Not to mention you can get 680 lbs in it. Here is a link. http://www.buywake.com/catalog/detai...h&sku=FL_ttJqn
                  • jhiestand
                    • 783
                    • Columbus, Ohio
                    • 08 Super Air 210
                    Sounds like Alan-S has a good lead on a sack. One other thing you'll want to do is get in the locker with a dremel or sander and check for exposed screws. I cut about 4 ends off to ensure I didn't have anything poking into my locker sack.
                    • bkhallpass
                      • Apr 2005
                      • 1407
                      • Discovery Bay, CA
                      Before you take out the kick panel, lift the Starboard bow cushion.
                      My heater is located there. (newer models have a cooler there). The core is not hard to replace. Six screws
                      and two hose clamps. Actually, mine is currently broken, so I removed
                      it and bypassed the heater core by connecting both ends of the
                      hose. I'll fix it later but didn't want to lose water time.
                      BKH
                      2001 Super Air
                      • NAUTIQUEjunky
                        • Aug 2005
                        • 61
                        • KERR LAKE NC
                        water in ski locker
                        Molly our 00 Super gets water in the ski locker as well, As far as I can tell it comes from the drain hole in the back of the locker. When you slow the boat ,water enters there from the bilge. You may have excessive water entering your bilge. My driveshaft packing is dripping more than I would like so I know thats where the water is getting in our bilge. Also I am using a freinds Get High Sports/ Big Bump 750 sac it fits very good in the ski locker...
                        ISN\'T LIFE BETTER IN A NAUTIQUE!!!
                        • Molly_2000SAN
                          • Mar 2005
                          • 20
                          • Minneapolis, MN
                          RE: water in ski locker
                          Thanks everyone for the information.
                          • jonfo
                            • 385
                            • Bellevue, WA
                            • 1990 SN 2016 G23
                            Does anybody know if the 211 has the same locker dimensions as the 210 or not?
                            -Jon
                            16 G23
                            07 220 TE
                            05 211 TE
                            95 SS (210)
                            89 SN
                            • MNSuperAir
                              • Sep 2005
                              • 591
                              • St Paul
                              • 2016 SAN 210
                              Molly, I have a small leak on my ballast knobs just to the side of my drivers seat that you may want to look at too.
                              2016 SAN 210
                              2006 SANTE sold
                              2001 SAN - sold
                              1991 Sport Nautique - sold
