Prop question on 2013 G23 with 450.
  • Devodad
    • Jan 2014
    • 13
    • Minnesota
    • 2018 G23 H6 2013 G23 450 2006 Mastercraft X 45
    Just bought 2013 G23 with a 450. It has the stock 2313 prop. I am concerned about performance when loaded down. Anyone use the 2419 prop with 0.075 cup? Will this help the hole shot and be able to handle more weight? Any concern about high RPMs with this prop?
    We typically do 90% wakeboarding and 10% surfing. Thanks.
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Yes, it'll work very well for torque and heavy weights... But understand you'll have a 34-36mph top speed boat.
    A 2315 is still a considerable upgrade over the 2313 tq wise. Faster acceleration when heavily ballasted. Roughly 2-3 seconds faster 0-23 with full OEM ballast over the 2313. Equates to you being able to carry 300-500lbs more where the 2313 would have got stuck. Decent increase in tq as described ^^... But not major earth shaking wow difference.
    2419 would work well for a 2013 450 G owner who wants to go "extreme". Would be another 1-2 seconds faster on your launch while ballasted and carry a little more weight than the 2315. But understand you'll have a slow slow boat, high RPMs, loud boat, and burn a lot more fuel.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • Devodad
      • Jan 2014
      • 13
      • Minnesota
      Thanks for the info. I am OK with the loss of top speed. I think we will go with the 2419 for the season. I assume the boat will be louder from higher RPMs.Our last boat was an MC X-45. We had sacs everywhere trying to building a bigger wake.
      • Live to surf
        • Apr 2013
        • 85
        • Sylvan Lake, AB
        • 2013 G23 450
        I put the 2419 onto my 2013 450 G23. It felt like a new engine! I did not time it or anything like that but time to plane and hole shot were noticeably faster. It handled the extra weight like a champ. I surf with OEM plus 2000 lbs water ballast plus people. Wakeboarding was much faster to plane with OEM plus extra ballast.
        I did not pay attention to gas consumption or RPMs so I cannot comment there. In the end I wish I would have put it on as soon as I bought it rather than end of season.
        • Devodad
          • Jan 2014
          • 13
          • Minnesota
          Thanks, that helps convince me to go with the 2419.
          When you are surfing do you have more weight on one side depending on goofy or regular?
          • Live to surf
            • Apr 2013
            • 85
            • Sylvan Lake, AB
            • 2013 G23 450
            When surfing, I primarily just run stock ballast and put people in the corner of the side the wave is on. I run NSS at 3 and NCRS is always at 5 for surfing unless I am pulling a beginner. I run 11.3 mph. At times when I have less people I will fill a couple of fly high 150 lbs bricks and move from corner to corner. This is because my crew has a number of goofy and regular riders and we are always switching sides. I prefer surf style over skim. The factory wave is lots of fun and long. I just have to pump a little harder for tricks.
            When I am the only one surfing, I will fill stock ballast and 1100 lbs in starboard locker. I also put 300 lbs on the starboard seat or people. I fill the port sac about 1/3 full which is approx 350 lbs. I run NSS at 0 and NCRS at 5. Speed is 11.3-11.5 mph. Wave is sweet. Steep, beefy and long. I usually have one or two adults in the bow with the kids. Tons of push. Don't do this often cuz it is a pain to switch sides but every chance I get I do. It is the best wave and a blast to surf.
            • SurfingCane
              • Jan 2016
              • 146
              • Raleigh, NC
              • `13 G23
              I know this is an extremely old post!!
              But I’m interested in the 2419 prop for the exact same reason mentioned above. I have the 2313 prop & OEM ballast, plus 1500 lbs of lead bags & then when we take friends or another family the boat won’t get up on plain when surfing unless I tell everyone to go to the front.
              Called WakeMakers & a tech guy told me that the 2419 is almost identical (except a small difference at the tip of the blades) to the 2313. That buying any prop would be a waste of money & time. That the 2313 (at the time in 2013 with my 450 motor & tranny) was the “upgraded” prop. He said “I’d love to sell you a prop but I don’t want you to be a pissed off customer when you find out it didn’t help.”
              But, going by the statements posted above it seems like the WakeMakers guy is wrong?!?
              Can someone please help & explain???
              Is there really no options or “upgrade”??
              THANK YOU!
              KEEP
              CALM
              AND
              WAKESURF
              ON
              • FMSki 'n Surf
                • Apr 2026
                • 42
                • Sproat Lake
                • 2007 SV-211
                Only the cup of blade - there is more spoon in the 2313, comes into play at higher RPMS (therefore higher top speed). You'd be able to drive more more torque in the 2313 for same RPM.
                The 2419 would be like one (or a 1/2) gear up on a bike, for easier pedaling up hills. Might be the difference you need, but maybe not.
                What speed are you trying to go? It breaks my mind to try to put my boat on plane fully ballasted. It's surf or putter along.
                The ACME 2419 and ACME 2313 are both 4-blade, 15-inch diameter by 12-inch pitch inboard propellers with a 1 1/8" bore, but they differ significantly in their cup size and performance characteristics.
                Key Specifications
                • ACME 2313: 15" x 12" with a .150 cup. [1]
