do you guys fill/empty ballast tanks with engine running or not?
  • Colbrofoot
    • Mar 2010
    • 8
    • S.E. Mich.
    • 2011 SAN 210 Team 1991 Barefoot
    Fill when warming up and idling out to where we start our run, If not full finish filling with engine off.
    Start emptying as we circle to pick up rider from last run of the day. Shut engine off for rider to get in and let it pump out while rider gets every thing stowed. If its late will drain while heading back to the dock, when its close to empty shut engine off to listen to the pumps so they don't run dry for to long.
    • ironj32
      • May 2011
      • 601
      • 2018 SAN G23 XR550
      The only time the boat is on is if we are going somewhere. Sometimes I fill/empty while we are going from point A to B.
      2018 SAN G23 XR550
      2015 SAN G23 XR550
      2014 SAN G23 XR550
      2013 SAN G23 XS550
      2013 SAN G23 ZR450
      2011 SAN 230
      2010 SAN 230
      2000 XStar
      www.mnspringride.com
      • Neverenough
        • Sep 2012
        • 907
        • Ft. Worth Texas
        • G
        I think the deal is amp draw with pumps running. I thought that a red somewhere where it said to run pumps while at 1500 or more rpm. Could have dreamt it!!
        • Nordicron
          • Sep 2009
          • 557
          • Madison, WI
          I believe that is what MC suggests
          • axeman
            • Apr 2012
            • 387
            • Dallas, TX
            • 2016 Super Air Nautique 230
            Typically fill/drain with engine off. Engine is only on when going from point A to point B and back.
            • durty_curt
              • Feb 2010
              • 52
              #21
              Originally posted by jonsquatch View Post
              I fill or drain mine whenever I feel like it. I have no problems with making adjustments depending on skill or with a rider slowing things down in the middle of a set to work on board control or getting a quick surf set in before they get out of the water when its colder out. We often fill/drain on the way from/to the dock to/from the riding spot at 20-23 mph if someone hasn't already started the process while waiting for me to park the trailer. Other times we forget and start the fill right as the first rider gets up to start getting ready, with 2 batteries I don't care if its with the engine on or off. If I am changing between riders I start the change just as soon as the rider signals they are done and continue right on through the rider switch with the boat off and its usually done by the time the second rider is starting their pull if not I let it finish while they are riding.
              Dear Jon, I'm sorry for running up the hours on your boat. It's a bad habit I will need to break on the Byerly.
              Sincerely
              Curtis
              • jonsquatch
                • Jul 2012
                • 251
                • AZ
                #22
                Sincerely
                Curtis
                Ha! I don't worry about it either way, especially when its cold out we leave it running for the heater/shower. My point was that on or off isn't particularly relevant and it runs fine at speed as well.
