Upholstery shops around winston, gboro, high point?
Anyone know of an upholstery shop around the Winston-Salem area? I'm having trouble finding the matching vinyl as well. Any help would be great. Thanks
Thanks for the info.
I called and they were more than happy to help, and didn't even ask if I purchased the boat from them. Sounds like a stand-up place.
I've removed all the interior except the side pads through the walkway to the bow. How the heck do you remove these?? I removed all the nuts I can find, looked up from the ski locker, behind every hole, and don't see anything.
The one at the kick panel is tight at the top, and the other side is tight at the bottom. Thanks
Well, I went with your idea, and there were no Christmas tree fasners but the panels came on out! The carpet on the bottom of the panels was so thick that they were applying pressure on the studs. Thanks
Most people put the unit behind the driver's kick panel. You can then run the vent lines wherever you want.
