MT, definitely sounds like you have some wet foam, water = weight, not good for the slalom wake among other things so you should remove it, you will need to cut/remove the floor and then dig the foam out. Replace foam and glass up floor.
If you decide to do it yourself I would suggest posting your questions on www.correctcraftfan.com, quite a few regulars there who have done full stringer jobs with new foam and new floors that should be able to answer all your questions.
