Engine compartment dividers 97 SS
  • Brichter14
    • Jun 2013
    • 537
    • Central Illinois
    What would be the best material to use for the engine dividers? I'm gonna be putting a 750 sack on each side of the engine and I need to keep the bags off the exhaust manifolds
  • Txpilot83
    • Mar 2012
    • 47
    • Texas
    • 1996 176
    You could try using starboard. I've used it on my boat with no issues. Cuts just like wood and will last forever. Hope this link words. I've ordered from these guys a few times and have no complaints:
    http://www.ebay.com/itm/1-2-WHITE-OR...item45f09d7ee0
    • jbach
      • Aug 2012
      • 187
      • the state, not the jelly
      • 1999 SAN
      Use the existing dividers. Go to
      Lowes and grab some 3/4" aluminum channel to strengthen them. Screw the channel into the too and bottom of all four dividers. I can post a picture of one if it stops raining.
      • Brichter14
        • Jun 2013
        • 537
        • Central Illinois
        Aren't the existing dividers too low for a 750 bag?
        • jbach
          • Aug 2012
          • 187
          • 1999 SAN
          too low? not at all. do you have both your pieces on each side? i can't really tell from the pictures.
          this is what you need to stiffen them up.
          http://www.lowes.com/pd_55981-37672-11385_0__
          • intrlaz
            • Aug 2009
            • 230
            I built mine out of this
            http://www.grainger.com/Grainger/wwg...rue&sst=subset
            It was a little bit too wide for the channel, so i notched it just the width of a saw blade. Now it fits perfectly. It is very strong and able to support my 750 fat sacs with no problem. The negatives are the cost, and they are heavy, which makes them a little unwieldy to pull out.
            • Jono
              • May 2010
              • 85
              • 1996 SuperSport
              I don't know if your boat is the same as mine - can't tell from the pic- but where will you secure the divider towards the rear of the hatch? I have an upright support in the front, and an L bracket on the floor - that's it.
              Also, will you be keeping the hydraulic lift?
              • s_kelley2000
                • 1593
                • Fort Meadow Recevoir
                • Mass
                I can't tell from your pics but it looks like you only have bottom part in as Jbach mentioned. Maybe in earlier years they made them lower? In my 99 there are two dividers that stack on top of each other that go all the way to the top of the compartment. The dividers are probably about 6-8" higher than a full 750 on my boat.
                Shawn
                2012 Blue Metal Flake SAN 230
                • scarbs
                  • Aug 2009
                  • 450
                  • Arizona
                  • 2017 G23
                  Like Shawn, I have a 1999 and it has two dividers stacked on top of one another. I lined the existing dividers with aluminum channel and capped them with a bigger, thicker piece of aluminum channel. Now they don't flex at all when the 750s are full. Instead of Lowes or Home Depot, I found a local shop that sells aluminum and bought their drops for like $1.50 per pound. I think the total cost for all of this aluminum was $35-$40.
                  2017 G23
                  2012 210 TE
                  1999 SAN
                  1995 Sport
                  1991 Sport
                  • jbach
                    • Aug 2012
                    • 187
                    • 1999 SAN
                    scarbs, i must have used yours as inspiration, mine look identical.
                    • Brichter14
                      • Jun 2013
                      • 537
                      • Central Illinois
                      I only have the bottom half of what you guys have. Each side has a support rail in the front and is held down by an L bracket in the bottom. I need something to go on top of it.
                      • s_kelley2000
                        • 1593
                        • Mass
                        I wonder if your current divider is the same size as the bottom divider on the newer ones that got two per side? If so I can take some pics and measurements of my top board to help you design yours if you think you need them?
                        For material I know people have had good luck with King Starboard and HDPE. You could probably get away with marine ply as well but don't quote me on that.
                        Shawn
                        • bhectus
                          • Sep 2010
                          • 283
                          • Gainesville, FL
                          • '02 Ski Nautique '87 Barefoot Nautique - sold '97 Super Sport - sold '96 SN196-sold '83 2001 sold
                          I believe the older boats only had the half stack dividers. My '97 SS had none in it when I bought it and I used white Starboard for the dividers. Worked out really well and the material is super easy to work with. The only drawback is it is a little more flexible than wood but if you use a stabilzer bar across the middle you should be fine. No wood rot to worry about! I got mine from a local marina/canvas shop. Think I paid $40 for both.
                          2002 Ski Nautique 5.7 GM Apex
                          • Brichter14
                            • Jun 2013
                            • 537
                            • Central Illinois
                            If you can give me the measurements of the top piece that would be awesome!
                            • s_kelley2000
                              • 1593
                              • Mass
                              They are kind of a pain to get in and out but I am planning to do an oil change in the next two weeks so I will be sure to get good measurements and pics then. I should be able to get some decent pics and measurements for you with them still installed this weekend though.
                              Shawn
