when you buy a new boat. where have you found your master code for link?
The dealer can get the Master embedded code or whatever they call it. However if you don't currently have a Primary user code setup (i.e. you just press start once to power the boat on and a second time to start it) then you can program both a Primary and Secondary code if you want one. There are instructions in the user manual, Programming the Primary User Code is on page 4-18, I have the page printed sitting on my desk to try it again tomorrow I didn't have much luck getting it to work last time I tried. If you don't have the manual handy you can download it from Nautique easy enough. If you have a code you use and want to change it you are supposed to be able to do that as well. The instructions are also in the manual. The only time you need to have the Master code is if there is a Primary code setup and you don't know what it is (i.e. you can't use the boat at all or you have a secondary code you are using) then it can be used to clear the Primary and Secondary codes.
All of the manuals are available on this site.
http://www.planetnautique.com/vb3/co...Owners-ManualsPlease do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
