I am currently looking to purchase a 95-99 super sport. If it doesn't already have a tower I was gonna put a FCT on it but I'm worried if it will fit through my 9x7 garage door. Does anybody have any input on this?
Is that 7 feet tall by 9 feet wide or vice versa? If its 7 feet wide the trailer will be too wide. Height will be tight if its 7 feet but will probably work depending on the trailer hieght. If it has an original factory FCT(98-99) then I don't think that will fold low enough and even if it does that tower is next to impossible to fold without an extra set of hands and even with help its sketchy if you have tower tower speakers. The 00-05 FCT should fold low enough and the New Dimensions Tower should fit as well.Shawn
2012 Blue Metal Flake SAN 230
You luckily have the more modern FCT so if the OP finds one with a factory 98-99 tower he is going to be real close but it may fit.Originally posted by Tom351 View Post[ATTACH=CONFIG]23416[/ATTACH]
My 99 Sport fits in a 7' door (actually measures 6'10") so you should be fine unless you have a trailer that holds the boat higher.Shawn
Great point- I forgot about the previous tower design with the pivot at the base.Originally posted by s_kelley2000 View PostYou luckily have the more modern FCT so if the OP finds one with a factory 98-99 tower he is going to be real close but it may fit.1986 Silver Nautique
1999 Sport Nautique
Just to clarify my garage door is 7 feet high and 9 feet wide. Ideally I want to find a super sport without a tower because I can put one on much cheaper than buying one with a tower.
Don't forget to consider the depth of you garage as a super sport on a trailer without a swing tongue will be too long. Usually you need to take the platform off and have a swing tongue to get that boat into a standard 20' deep garage bay.Originally posted by Brichter14 View PostJust to clarify my garage door is 7 feet high and 9 feet wide. Ideally I want to find a super sport without a tower because I can put one on much cheaper than buying one with a tower.2018 Ski Nautique 200 TE, H6
So I need to find a SS with the newer tower (99-01) or find an older one without a tower and put an aftermarket tower on it. I would really like to be able to collapse and raise it on my own.
Depth of the garage is not a problem. I am lucky enough to have a detached "man cave" that's 27'x31'
this is what I'm doing now
