Ballast setup question
  • perry386
    • Jun 2012
    • 560
    • gadsden AL
    • Super Air nautique 236
    Hey guys, Lately I have been noticing it more and more difficult to just go wake-to-wake. Every time I end up going out into the flats which is just painful and not very fun. I am still getting good height (as shown in the pic) but just going to far out. I was thinking that maybe I should steepen the wake a bit. Is that the right answer or is something else involved? Anyways, I would like to know what you guys are running for ballast in a 230. Right now I'm just running full factory ballast at 75' but am debating stepping it up to factory ballast plus a 400 sac on each side halfway full.
    It is a little blurry but you can kinda see me and the wake.
  • slob02
    • Sep 2003
    • 333
    Lengthen the rope a section.
    2008 Super Air 210 Team
    2004 AIR 206 Team
    1997 Ski Nautique 196
    1993 Ski Nautique SNOB
    • perry386
      • Jun 2012
      • 560
      • gadsden AL
      Would I be able to keep the same speed? I am right at the edge of rideable wake where its at. I'm afraid that if I go back any then I will be behind the good part of the wake.
      • northwestwater
        • Jul 2012
        • 64
        • steilacoom lake, WA
        • 2000 calabria 2004 SV 211 2006 220 2009 230 409 hp 2013 G23 550 hp NSS
        hi Perry! i think you look good out there! i agree with slob 2 but, also might add that if you decide to try to add fat sacs in the rear only, the 230 will start to porpoise every time you hit a little bump in the water. you would probably have to add a sac in the ski locker and also a little weight under the bow seats to quiet the boat down. i had to have a fair amount of weight in the bow to keep the boat from bouncing down the lake in my past 230. i had my dealer plumb the sacs to my hard tanks so i didn't have to fill all the tanks separately each time i went out. oh, and i also found the 230 to be fairly sensitive from port to starboard, which is also a good reason to to have it plumbed in so you can make fine adjustments once you start riding.
        have a great summer!
        2013 G23 550 NSS
        2009 230 409
        2006 220
        2004 SV 211
        2000 calabria
        • perry386
          • Jun 2012
          • 560
          • gadsden AL
          Thanks for the help guys. I've always looked at as: Weight in the back=Vert, weight in the front=Ramp. I guess that's not exactly the case. I might just try adding more weight everywhere in the boat or speeding up to 22-22.5 and lengthening the rope out to 80'.
          • s_kelley2000
            • 1582
            • Fort Meadow Recevoir
            • Mass
            In general that thought process holds true but if you get too much in the back it will make the boat porpoise and handle very poorly. If you like the shape of your wake then your best bet it add weight evenly to keep the shape the same and make it bigger and firmer. Backing your rope out to 80' might widen it enough so you are still landing on the down slope instead of the flats. If you are riding a continuous rocker board you might want to try out a 3-stage board that will give you a more abrupt straight up pop.
            Shawn
            2012 Blue Metal Flake SAN 230
            • perry386
              • Jun 2012
              • 560
              • gadsden AL
              Ok thanks, will try a linger rope next time I'm out. Can't exactly go and buy a new board right now as I JUST bought this LF Trip and so far am really enjoying it other than this one thing.
