This is probably a stupid question but what are you guys using the compartment under the reversible seat for ? I definitely think its a good hidden compartment in the boat for anything illegal haha but not sure what its purpose is !!
I put my docking ropes there. They are not used much and our out of the way.2013 G23 450 with NSS (175hrs) and still have the original prop
2010 SANTE 230 343 (280hrs)
G owners, has any one got a fuel comparison between the 450 and 550 motors? still struggling on what option to go. The other one is can you run rev10s or rev410, do the 410's work with the factory bimini or do the speakers fowl on the bimini arms?
just remember , what ever you place in it will eventually get wet with that tidal wave coming over the back, I used to keep babes and an cleaning rag but when i went to get it one day it was soaked.I know how to avoid. but every once in awhile you have a new driver or you just need to stop fast, without a slight turn!!2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
I had the ZR 450 last season, and now have the XS 550. I seem to be running about $5-10 more per set. This isn't really an apples to apples comparison, however, as I'm running about 1000 more pounds of ballast (was running factory + 2200 extra). Seem to be running about $35-$45/set...obviously, a big factor is how much I fall. If I'm trying new stuff or am having a rough day, it'll be a bit on the higher side.Originally posted by bradw View PostG owners, has any one got a fuel comparison between the 450 and 550 motors? still struggling on what option to go.
I will say that the XS 550 is an AWESOME engine. With the extra 1000 pounds of ballast over the 450, I'm running at about 500 fewer rpms. Hole shot and turn arounds are no problem at all. The boat typically doesn't fall below 21 mph in a fairly tight turn around. Top speed, empty, is only about 3 mph more than the ZR 450. She tops out at about 42 mph, with the factory prop.
If your going to be staying at or below factory ballast + <2000 (extra ballast and people), then I think the 450 is fine. If you want to run more than 2000 pounds extra, then I'd say consider the 550.2018 SAN G23 XR550
2015 SAN G23 XR550
2014 SAN G23 XR550
2013 SAN G23 XS550
2013 SAN G23 ZR450
2011 SAN 230
2010 SAN 230
2000 XStar
www.mnspringride.com
McFarland I learned that on the test drive haha whoops !! Rookie G mistake for sure lol
BradW Rev410s will not work with factory bimini I tried to go that route. Instead I had to go with the rev10s they worked out nicely !! I do not have any info on the difference between the motor but ironj knows what he is talking about in that category for sure !
Pics of the rev10s
gate- holy crap.
Iron- can you post up some pics of your wake when you are sac'd out like that? would appreciate to see what it looks like.2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
Jay - how long are your typical sets, about 30 mins? I seem to be averaging about 8-10 gallons/hour over the entire tank of fuel. That would put me about $32-$40/hour. That is about 65% wakeboard with factory ballast + 3 people, 20% wakeboard factory + 2500 pounds and 15% with stock ballast.
Originally posted by ironj32 View PostI had the ZR 450 last season, and now have the XS 550. I seem to be running about $5-10 more per set. This isn't really an apples to apples comparison, however, as I'm running about 1000 more pounds of ballast (was running factory + 2200 extra). Seem to be running about $35-$45/set...obviously, a big factor is how much I fall. If I'm trying new stuff or am having a rough day, it'll be a bit on the higher side.
If your going to be staying at or below factory ballast + <2000 (extra ballast and people), then I think the 450 is fine. If you want to run more than 2000 pounds extra, then I'd say consider the 550.2021 G23 450 - Current
2019 G23 450 - Sold
2018 G23 450 - Sold
2017 G23 450 - Sold
2016 G23 450 - Sold
2014 G23 550 - Sold
2013 G23 450 - Sold
2012 210 - Sold
2012 200 Mapple - Sold
2011 230 - Sold
