Stock Weight 2008+ 210 SANTE
  • Clibka
    • Dec 2012
    • 406
    • Illinois
    • 2021 G23 2012 210 SANTE (Previous)
    Does anyone have the OFFICIAL word on what the stock tank weights are in a 2008+ 210 SANTE? What are the individual tank weights?
    First and Current - 2012 210 SANTE
  • Nautiquehunter
    • Jun 2008
    • 2099
    According to the 08 brochure the max stock ballast is 773 lbs.I could be wrong but I thought the stock rear tanks were 300lbs each.
    • Clibka
      • Dec 2012
      • 406
      • Illinois
      It's amazing how difficult it is to find this information. I would think it would be common knowledge?!?!?
      • perry386
        • Jun 2012
        • 560
        • gadsden AL
        • Super Air nautique 236
        you got anything on the 230? I've heard 1000 but wanting to make sure
        • Nordicron
          • Sep 2009
          • 557
          • Madison, WI
          My old boat buyers guide for the 2010 models show 906lbs. Seems like all three tanks are the same size as they all take the same time to fill.
          • Nordicron
            • Sep 2009
            • 557
            • Madison, WI
            • Nordicron
              • Sep 2009
              • 557
              • Madison, WI
              Here is the 230 spec:
              • Clibka
                • Dec 2012
                • 406
                • Illinois
                Now the real question:
                to pull or not to pull?
                If I pulled them I will put 1100's in their place, if they stay I will put 750's on top. Integrated bow bag either way. This is a tough decision for some reason!
                • Nordicron
                  • Sep 2009
                  • 557
                  • Madison, WI
                  [QUOTE=Clibka;201291]Now the real question:
                  If I pulled them I will put 1100's in their place, if they stay I will put 750's on top. Integrated bow bag either way. This is a tough decision for some reason![/
                  I say keep them and go with 750s. I plumbed mine in with quick connects so I can take out and use a 750 in the middle of the boat when surfing! That way still have the hard tank in to keep some weight on that side. I also like the hard tanks in so the gauges still work, I can tell when stuff is empty! With hard tank in and 750's you will have more weight than u possibly need. So much so that you will not be able to fit enough in the bow without resorting to lead or another bag on top of the now cushions.
                  • offshorejay
                    • Aug 2010
                    • 65
                    • NJ
                    • 1997 Ski Nautique 176 2021 Centurion Fi23
                    belly tank is 349 Lbs
                    Rear tanks are 279 Lbs each
                    907 lbs Total
                    • Clibka
                      • Dec 2012
                      • 406
                      • Illinois
                      Originally posted by offshorejay View Post
                      210-
                      907 lbs Total
                      You are the man Jay!!
                      So it looks like a piggy back isn't doing as good as we all thought? (weight wise, performance is what matters and we know it is still a good setup) if the rears are 279 you put a 750 on top that maybe fills to 700 you get 979 per locker. and the front integrated bag, from what everyone says, is only filling 60-80% lets call it 500 + 349 = 849 up front. Total weight available is 2807#'s with a distribution of 30% up front and 70% in the back.
                      • HS
                        • Oct 2007
                        • 1333
                        • Sammamish, WA
                        • 2010 SANTE 210 (Sold)
                        So are you back to the 1,100 pound sacs, then?
                        • Clibka
                          • Dec 2012
                          • 406
                          • Illinois
                          I don't think so. I'm out here playing around in the lockers right now and pulling the hard tanks seems like a bigger pita than I want to deal with. Plus ... I would miss the gauges I think.
                          750's will be ordered Monday. As well as the integrated locker sack.
                          Someone should tell correct craft that hard tanks aren't the answer.
