I have an 2004 San with 200 hours. I bought it late last season and had it winterized. Took it out today for the first time and after a short morning run of an hour or so docked for lunch. Ran the bilge pump and it ran for 5 plus minutes. Took it out after lunch for two hours and when I got back ran the bilge pump for eight plus minutes till it drained all the water. Seemed like a ton of water. Also when I opened the engine hatch the foam was wet and the top of the engine cover had water on it. I don't recall this happening last season. I am new to boating--is this an issue if so what should I lookk for? THANKS.
Well the good news is if they screwed up the winterization and damaged your boat they're liable for the damages. I have a couple friends that have places on Horse Shoe Bay/LBJ. Aren't there a lot of sandbars on that lake? They are always hitting the bottom and chewing up props.
Bay Marine usually does a good job, and we did have much weather to be worried about this winter. With everything that drains into the I would say it is rare for it to be totally dry, the pump won't get it completely. Somethings leaking, most likely the packing gland. Where on LBJ are you? I'm way up the Colorado arm and would be glad to take a look if you want to bring it by my dock.
You could have a cracked hose, loose strainer (or perhaps missing the o-ring), or loose hose clamp (especially around the impeller pump). I'd run the engine for a few minutes with the hatch open and watch (while someone else watches the temperature gauge... and shuts off the motor if it gets above 160). Many of these will result in the engine overheating. If you see the water coming from a hose or hose connection or uncapped plug or impeller pump, you have found your culprit. If not, then as mentioned before, it is probably coming in through the shaft packing (or possibly a loose hose clamp on the exhaust... my first boat (Tige) direct drive had that happen). I'm assuming of course that the boat plug is in!Now
Oops, meant to say we didn't have have the kind of weather that tends to freeze motors this winter.
you definitely need to run it with the cover open. if you have water on top of the engine cover, it sounds like a pretty good leak. should be very easy to spot. let us know what you find. 8 mins is a long time also.04 SANTE 210
89 SPORT
