So I've been searching for a 2001-2003 SAN for quite some time now. I have looked at a lot of them. I found a super nice one that is mint inside and out, but when I went on the water test it had a slight vibration when opening up the throttle wide open and running 30+mph. The seller thought it was a normal vibration and never noticed it because he never ran the boat that fast, but having owned a 99 SAN that I would run fast quite often I felt it should be a lot smoother on top.
We pulled the boat and the prop had a of couple dings to it and he said he remembers hitting something at idle, but never really thought much of it because the boat ran fine afterwards. Two of the 4 blades had a decent bend to them so I told him he would need to have the prop re-worked and water tested before I would buy it. He had it re-worked and went for the water test yesterday and he reported back to me that he didn't really notice a change and still feels as though the vibration is normal.
What should I do? I've thought about taking it to a dealer and having the driveshaft alignment checked and see if they could throw a different prop on there and see if that smooths it out. I have read that even a re-worked prop does not correct a vibration while a new one will. Let me also mention that the prop spins freely using one finger to spin it.
I hate to pass on the boat because it is by far the cleanest, nicest looking, and most well taken care of boat I have looked at to date, but I also don't want to be looking at a huge driveline repair bill to get it running smoothly.
