individual ballast control
  • andmarthow
    • May 2011
    • 21
    • Starkville, MS
    • 2002 SANTE w/ 8.1L Python 1992 Nautique Excel, Ope
    I have a 2002 Super Air TE and would like to modify the system so I can individually fill/drain each ballast tank. If anyone has accomplished this, please post your approach, where you mounted your extra switches, etc. Photographs would be appreciated. I do not want to modify the boat any more than I must.
    • Aug 2026
    wakemakers tankbuster kit. http://www.wakemakers.com/99-02-naut...t-upgrade.html
    You will also need to add another drain and fill pump (if you stick with aerators) and separate the system. It should be pretty easy to do. Call Jason or Spencer at Wakemakers and they can walk you through it.
    • johnboyy7
      • Oct 2009
      • 409
      • houston
      i have an 04. i thought our boats were similar in that each tank in the back has its own fill/dump pump. is this not the case? i added automatic valves due to the flow wrongs not working.
      04 SANTE 210
      89 SPORT
      • andmarthow
        • May 2011
        • 21
        • Starkville, MS
        Yes and No. My boat has a fill/drain pump per tank, but electrically they are all operated simultaneously; one fill switch, one drain switch. Right now, if I want to just fill a specific pump, I simply valve out that fill pump via the manual valve. Its pretty easy, but it does dry run the valved-out pumps. Draining on the other hand, its all or nothing.
