Hey there, I'm looking at an 04 210 TE and it only has 225 hours. The guy says he kept the boat on the side of his house under the fitted boat cover. The vinyl all looks good, the gel-coat looks good, but the guages are VERY cloudy and the volt/amp meter doesn't work as well as the guages for the for the ballast don't work. Would you suspect it was put up wet and they just baked in the FL sun? Is this a common problem? Here is a link to the boat so you can see for yourself. http://www.parkerboats.com/Page.aspx...ue-SK-210.aspx Any other questions to ask to avoid a problem boat? I like the color combo and low hours, but really don't have the patience, time, or money for a problem boat!
Part two of my question... I am also looking at an 05 210 but it only has the LE package, but it's about $30k. It has 3 ballast tanks, FCT, and Perfect Pass. It isn't my color, nor a TE, but it is very clean with less than 200 hours. Should I avoid the blue boat (04 TE) even though it's a TE and take the newer less expense boat even though its an LE? I'm thinking value and return on investment when it's time to sell as well as the overall boat.
Thanks so much in advance for your help!!!
