Just bought 04 SV 211 TE. It has excalibur engine and 4 blade prop. RPM are running about 3300 at 22 MPH and about 4500 at 32 MPH with only 4 crew and no ballast. Does that seem normal?
RE: sv 211 te RPM range
Seems high to me, what's it spin at WOT? My 211 has the Signature prop, 13.5x17.5 and it only spins 4800 rpm WOT at 46MPH, your boat should spin a little more with the 13.25x16 prop but I don't know if it should spin that much more.
that sounds about right Joe. if you are WOT 5200 , then 44-45mph (where is the hydro gate?) with the 13.25/16 prop is about right.. That prop assumes you are running loaded with full ballast tanks, so it is pitched lower such that you don't lose your holeshot. going with the signature prop, like mike. you'll get more top end, but there may be a compromise on the low end, when you are weighted. Mike , chime in on the 17 prop with ballast ...2004 SV-211 Team
Silver cloud deck, Onyx Hull.
- Mar 2004
- 487
- Birmingham, AL
- 1985 Southwind 20 1987 Ski Nautique - New 1989 Ski Nautique - New 1992 Ski Nautique 1997 Ski Nautique 1998 Ski Nautique - New 1989 Martinique 1999 Sport Nautique 1999 Air Nautique 1988 Ski Nautique 1998 Sport 2004 SV-211 - New 2005 SV-211 1993 Ski Nautique 2002 Ski Nautique - New yellow black 2002 Ski Nautique orange black 2002 Ski Nautique blue black 1999 Super Sport Masters blue 2006 220 TE - new Lime Green 1997 Ski Nautique red black 2000 Ski Nautique Masters - Navy
The TE comes with a prop that is set for wakeboarding not cruising- thus higher RPM at lower speeds. You can change the prop to make it more of a cruising boat, with less out of the hole power and lower RPM<
