I'm going to add a wired transom remote to my 2011 210 and wondered if anyone had any advice/experience on the placement. It will be on the port side (easier to run a wire to from the head unit) and can either be above or below the step. Above the step is further from the waterline but the surface has a curve to it. Below the step has less of a curve, but is close to the waterline. With full aftermarket ballast, my swim platform is well below the water so I'd prefer the higher location, but wasn't sure about the curve. Has anyone else mounted a remote in this location?
