starter location PCM excalibur
  • keegan
    • Mar 2011
    • 66
    • vancouver, BC
    i know, i know. but seriously i cant find it.
    i have a 2007 SANTE 220 with a PCM excalibur 330.
    i have searched this forum and have found nothing on changing out the starter tips or DIY.
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    I think it is down low in the usual location for small block chevy's. That's where mine is. I'm thinking yours would be on the port side of the boat since your engine is in backwards.
    • keegan
      • Mar 2011
      • 66
      • vancouver, BC
      so port side front bottom?
      any advice (or DIY on changing it out)?
      • RideButter
        • Feb 2011
        • 189
        • Fuquay-Varina, North Carolina, United States
        • 2015 A22 2014 A22 SOLD 2009 210 SOLD 2007 210 SOLD
        that's where ours is on our 210 with the EX330
        [URL="http://www.ridebutter.com"]http://www.ridebutter.com[/URL]
        • CradGen2
          • Aug 2020
          • 1343
          • Horseheads NY
          Look for the red wire and follow it to the starter. Mine was behind some blower vent hoses.
          • AirTool
            • Sep 2007
            • 4049
            • Katy, Texas
            Crad: In my DD 206, mine is well hidden as well.
            All: This is not a dumb question by the way. I've seen several inboard outfitters that move the starter up high and bolt it directly into the bell housing for lack of better term.
            • teamseal
              • Dec 2006
              • 412
              • Panama city, Florida.
              • 2008 196, 1992 Shamrock 20' center console, 1965 Rickshaw race boat, 2017 ski 200 H6.
              Thats referred to as a top mount starter. I really am supprised that Nautiques has not specd out their motor packages on V-drives to include a top mount starter, or PCM only provide V-drive packages with top mount starters. Makes life easier for their customer! Hint!!
              • CradGen2
                • Aug 2020
                • 1343
                • Horseheads NY
                I agree. They should move the starter up. Would also help keep it out of moisture or water. I think Marina Power does this on their motors.
                Keegan - if you haven't already done so, remove the plastic side panels it will make life easier as you get your head down there. I think once those panels are out you will have good access. Question, why are you replacing the starter? You will be the second person recently to replace a starter on a late model nautique..
                • AirTool
                  • Sep 2007
                  • 4049
                  • Katy, Texas
                  Maybe it is a safety feature in the sense of enclosure fumes....rising up. The starter is clearly an arcing/sparking device. The rest of the claptrap up top is fairly sealed or intrinsically safe. Just thinkin'.
                  • keegan
                    • Mar 2011
                    • 66
                    • vancouver, BC
                    CRAD i was thinking about replacing the starter because a few times when i went to start the boat it just clicked and did not start.
                    i made a post here and i was told "replace the starter, that is your problem"
                    i cleaned the engine ground and it has not happened again as of yet. if it happens again i will replace the starter.
                    -keegan
                    • teamseal
                      • Dec 2006
                      • 412
                      PCM offers motors as do most all the marinizer's with top mount starters. When I re-power center consoles and even some salt water direct drives I always utilize a top mount starter configuration. Marine top mount straters are ignition protected just like the bottom mount style.
                      V-drive boats in my experiance have alway's been more subjected to excess water in the bilge then direct drives. Bottom mount starters are the first to get wet so to speak and have a higher failure rate under those conditions then would a top mount.
