I think it might be a bad battery if you have to keep a charge on. I have never put a battery charger on any of my boats and they stay out side year round ,covered boat slip. Run stereo all the time, even a lot while the engine is off , just make sure you always use the toggle switch (all-power off} when you are finished for the day.
2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
Interesting discussion. I've had a couple of instances where my batteries drained in a 2 - 3 week period of sitting, I think primarily from the bilge pumps running after heavy rains (and w/ factory cover, prior to getting a Coversports). Hopefully so much running of the bilge pumps is now a thing of the past. Last summer I alternated batteries, running on A for a day, then B the next outing, and A+B while sitting (rather drain both batteries than find a sunk boat).
GCsuper, which onboard charger are you using? Happy w/ it?
Wakeslayer, you don't have to charge your batteries in the spring? They maintain a charge over the winter?
Originally posted by SkiTundra View PostWakeslayer, you don't have to charge your batteries in the spring? They maintain a charge over the winter?the WakeSlayer
1968 Correct Craft Mustang
Originally posted by SkiTundra View PostInteresting discussion. I've had a couple of instances where my batteries drained in a 2 - 3 week period of sitting, I think primarily from the bilge pumps running after heavy rains (and w/ factory cover, prior to getting a Coversports). Hopefully so much running of the bilge pumps is now a thing of the past. Last summer I alternated batteries, running on A for a day, then B the next outing, and A+B while sitting (rather drain both batteries than find a sunk boat).
the books say that you should not leave the chargers on unless well ventilated?? i think if a battery were to go you would be equally as F'd weather the cover was on or off.
if i had a boat that i left outdoors and covered, i would have no problem running a cord and a charger under the boat. if anything the heat of the charger would keep some moisture out of the boat.
-keegan
