my brand new 210 doesnt fill the ballast tanks.. which sucks big time. first only the belly now the port one too.. i opened the pump to find out that the shaft in the green wheel slips big time and is not gripping to pump the water.. is this a common failure with those pumps??
You need to replace your impellers. Order a couple extras.the WakeSlayer
1968 Correct Craft Mustang
swap your impellars with the yellow ones, done.
I had the dealer swap all 3 before I took the boat home for the first time.Migs
G21 - En route
SAN 210 TE (Finally)
06 Sky Supreme V220(previous)
05 Sanger V210(previous)
01 MC X1(previous)
99 Air Warrior(previous)
thanx.. yeah.. i bought new ones.. works fine.. pitty tho that the original ones are worn out on a brand new boat!
