clean air systems
  • CD
    • Oct 2008
    • 87
    • British Columbia
    • 2008 216 Air Nautique
    clean air systems
    Anyone know anything about adding this to ones boat? I have a 2008 216 DD TE. thanks!
  • CD
    • Oct 2008
    • 87
    • British Columbia
    Maybe that wasnt clear, i am looking for a fresh air exhaust as we notice the fumes when surfing
      • 17030
      They are very easy to install, and seem to work well. Do you have any specific questions?
      Also, if you decide to order one, please order it through this link. That way, PlanetNautique gets a commission on the sale!
      http://www.freshairexhaust.com/aff_h...a_bid=c884b200
      • CD
        • Oct 2008
        • 87
        • British Columbia
        Is this the best system out there? I know the website says that it does not affect the wake for skiing or wakeboarding but is that what people who have it installed are experiencing? Is it really needed i guess too?
        thanks Jeff
        • Shooter
          • Apr 2026
          • 264
          • Orange County California
          • 2003 SANTE 210
          I believe that FAE has the patent, so it will be you’re only CC aftermarket option. I don’t have one, but the pipe does not extend down far enough to affect the wake. It is one of the few upgrades / aftermarket parts that get almost no complaints (from what I have read). It’s a must have if you surf a lot.
          • Red57Bird
            • Aug 2007
            • 381
            • Raleigh, NC/Lake Gaston
            • 2003 Super Air
            Do a search on "FAE" or "Fresh Air" and you will find several threads from those that have installed FAE. Most if not all seem to be very happy with the product and company.
            2003 SAN (current)
            2003 Chaparral 220 SSi (sold)
            • CD
              • Oct 2008
              • 87
              • British Columbia
              I have a friend that has a Malibu waksetter and all they did was put like a turn down on the exhaust, they are chrome almost like a chrome extentsion you put on a car. Is that effective?
              • CD
                • Oct 2008
                • 87
                • British Columbia
                k found what i was referring to earlier, are these available for Nautiques? Do they do the job like FAE?
                Turn Down STE Stainless Exhaust Port (each)
                Product Description:
                This stainless steel turn down silent tip exhaust port with built in baffle, does not need flappers. Helps eliminate exhaust noise and helps reduce exposure of carbon dioxide to riders.
                Fits on Malibu's with 3 1/2 inch exhaust (most models 1996 to current)
                • chris196
                  • Mar 2007
                  • 223
                  I don't know anything about this product, but take a look at how it hits the water. Is it in the centerline of the boat? If not, it will affect steering. The FAEs have the necessary bend in them to get them centered so the boat tracks straight. It also causes the boat to steer just a tad slower because it's acting like a rudder back there, but only noticeable doing very tight maneuvers going very slow.
                  FAEs are great. I put on a Ski Nautique that is pretty much only used for slalom and I really like it. If I was surfing, it would be a must.
                  • CD
                    • Oct 2008
                    • 87
                    • British Columbia
                    there was no difference in the tracking or the ski wake with the FAE then?
                    • chris196
                      • Mar 2007
                      • 223
                      Like I said, there is a little difference when doing slow manuevers, like docking. It's really just a slower turn rate, but at speed it's not noticeable. But FAE makes sure it's on the centerline of the boat.
                      the ski wake is the same as far as I can tell. There is a small rooster tail at skiing speeds, but it's not an issue for me.
                      • CD
                        • Oct 2008
                        • 87
                        • British Columbia
                        I have been hearing from some others as well that it affects the steering, has anyone else experienced this?
                          • Apr 2026
                          I have not noticed mine affect steering. That does not mean that it doesn't affect it slightly, it just means that I have not noticed it.
                          As far as that other product goes, it may or may not reduce much carbon dioxide, but that is pretty irrelevant, since it is carbon monoxide that is the killer. I have noticed a definite improvement in smell, or lack thereof, since installing mine, and used to get headaches often after a day on the boat, and since installing don't remember any (except when I catch an edge and do a major slap on the water).
                          If you surf a lot or short-line wakeskate a lot, I would definitely get one. If not, then it is less important, but still helpful to those who sit in the back seat.
                          I did have to put the hose clamps on the opposite way they tell you to keep it from coming off the exhaust flange. Since then, no problems.
                          • CD
                            • Oct 2008
                            • 87
                            • British Columbia
                            thanks, i am not sure i am convinced yet about this product, do they have a money back guarantee?
                            • Shooter
                              • Apr 2026
                              • 264
                              • 2003 SANTE 210
                              Not sure what you want to hear. I doubt they have money back because each one is made for your Nautique measurements. Maybe you should contact them.
