Towing a 09 210 with a 08 Tahoe
  • jefe
    • 257
    • Orlando, FL
    Anyone know what kind of drop you need, I hear 4-10 inches, but am not quite sure, it is a Eagle tralier. I have the air leveling system on the Tahoe, so it's not going to drop nearly as much as without it.
    I am thinking of getting a B&W Tow n Stow, which is a multi level hitch, but now sure I need a 10 incher, its significantly more expensive than the 6 inch.
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    Is it a single or Dual axle Eagle. I would get a level and find the same trailer. Jack it level on a level surface and measure from the ground to the top of the hitch. In my DHM dual it's 19" Then take 400 lbs (average tongue weight) and put in the back of the Tahoe. Then measure to the middle of the receiver. The difference is going to be the drop you need within an inch. I think with a dual axel its more critical so you load the tires evenly. Good luck. By the way I tow mine with an 05 Tahoe with a 3" drop.
    Nautiqueless in San Diego
    • cedarcreek216
      • Oct 2009
      • 1009
      • Dallas, TX
      • 2018 210 2013 210 2009 216V
      I never even thought about this. I tow with an 03 Z71 Tahoe and only have a 2" drop on it. I never thought I would need more than that. Guess I should go to the shed and hook it up and do some measuring.
      • NautiDave07
        • Mar 2008
        • 333
        • Louisville KY
        • 00 SAN210 07 236 TE
        A 10 inch drop on a tahoe would drag the ground. a 2 inch drop is probably right up your alley.
        00 SAN 210 (previous boat)
        07 236 te sold
        • 83ski2001
          • Dec 2009
          • 81
          i tow my 83 2001 nautique with a 2wd 97 f250 with no drop and its level, i cant see ur truck being much higher than mine, its a heavy duty. i would say no more than 2 inches
          • jefe
            • 257
            • Orlando, FL
            Thanks Rick!
            Well, I did measure from the middle of the hitch to the ground and it is 25 inches. With the auto-leveling shocks, I don't think its going to lower more than an inch, so lets just say it is 24 inches from the middle of the hitch to the ground. Unfortunately, I don't have access to my boat and dual axle trailer right now.. If I was to use the DHM trailer measurement that Rick provided, and level would be 19", then I would guess that the 6 inch drop is all that I would need. Anybody have a measurement of a level Eagle trailer with 15 inch rims handy
            Thanks!
            • bobchris
              Banned
              • Apr 2006
              • 359
              Originally posted by jefe View Post
              Thanks Rick!
              Thanks!
              with the level ride system your not going to see it drop any loaded or unloaded it has a sensor and will adjust it's self back to the same ride height, if it doesn't then you've got the vehicle over loaded.
              • azeus17
                • Feb 2008
                • 387
                • Grand Rapids, MI
                • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
                When I bought my 07 Tahoe, I though that I would be fine with a 2" drop. Had to make a return trip to the auto store to get the 6" drop when the jack would not even go high enough to get the trailer on the hitch. These newer body style full size SUV's from GM have a high hitch mount on them.
                • wetfoot
                  • Jan 2004
                  • 90
                  • SoCal
                  I use a 6" drop for my 216 (tandem axle trailer) on our 2009 Yukon with Autoride.
                  • jefe
                    • 257
                    • Orlando, FL
                    Perfect, thanks for the info!
                    • Quinner
                      • Apr 2004
                      • 2246
                      • Unknown
                      • Correct Crafts
                      My Tandem Eagle w/14" tires under a 206 is around 17.1/2" to the top of the ball. You may want to check their site for additional info.
                      http://www.eagletrailer.com/
                      • verhagmr
                        • Sep 2007
                        • 46
                        • Waupaca, WI
                        2'' drop is perfect. I have a 09 Tahoe and tow both a dual axle and a sigle axle (both Eagle trailers) and the 2'' is perfect for both...
                        2008 Ski Nautique 206
                        2006 Air Nautique 211
                        1986 Boston Whaler
                        • migs
                          • Aug 2008
                          • 707
                          • San Mateo, CA
                          • SAN 210 TE
                          3inch drop on my 06 Yukon
                          Migs
                          G21 - En route
                          SAN 210 TE (Finally)
                          06 Sky Supreme V220(previous)
                          05 Sanger V210(previous)
                          01 MC X1(previous)
                          99 Air Warrior(previous)
                          • ksarbau
                            • Mar 2008
                            • 52
                            • Indianapolis, IN
                            • 2016 G23
                            I use a 6" drop to tow my 211 with an '07 Tahoe with autoride. My trailer is a tandem ramlin. The prop guard still drags too frequently IMO but I don't want to take it any lower. It's crazy how high the reciever is on the newer tahoes!
                            2007 Air Nautique 211
                            • verhagmr
                              • Sep 2007
                              • 46
                              • Waupaca, WI
                              I think the hitch is higher on the newer body style because the reciever is built right into the bumper whereas the older body style the reciever hung below the bumper...
                              1986 Boston Whaler
