Slayer,
You can "T" into the raw water intake, before the impeller. It doesn't effect the cooling system. I've only seen it done with reversible pumps. People do it because they dont want to drill through the hull.
It's the same idea as the Flush-Pro. You can even use the Flush-Pro as the "T". They come with a device that keeps the check valve open. Your limited on the amount of gpm's you can flow.
