Guys,
Does anyone know what the thread size is of the end of the EZ Drain oil tube that is on the ZR6 engine?
I don't have a trailer so it is a bit difficult to get under the boat to drain the oil however the following link has a post on wake world where a guy hooks a vacuum pump up to the drain tube and sucks it out that way. I know you can drain it through the dipstick but that usually doesn't get all of it out unless you are very good at getting the tube down to the bottom of the lowest point on the oil pan. This method sucks it out of the drain tube which will ensure that it all comes out and you don't need to get under the boat.
I am looking at what size reducer I need to get (see link below). The garden hose to pipe thread adapters are 3/4" pipe threads so I just need to figure out what size the reducer needs to be: 3/4" pipe thread to WHAT?
I can do some trial and error but figured I would ask if anyone knows off the top of their heads.
Link: http://www.wakeworld.com/MB/Discus/m...tml?1077646658
