Blower was working fine most of the day and then all of the sudden it quit. Everything else on the panel works fine. Could it be a fuse? I dont know where to start. I couldnt find any fuses to the blower. Any Ideas?
RE: Blower wont work
I am guessing the blower motor is faulty. Even if the breaker/fuse is tripped/blown, something caused it to trip/blow....more than likely a burned up blower motor. But, there is always the possibility that a wire was chaffed and shorted against something metal.
In my 02 210 the blower will cut out whenever there is a bit of water in the bilge. Make sure its all drained out and let it dry (hang out for a while with the hatch open) then check the breakers. You won't be able to find and reset the breaker until it wants you to. Check your rear bilge pump too, mine worked fine but came loose from the floor and was actually floating, so it wasn't ever pumping.
