Just wondering what the trick is to balancing out the wake on this boat. It throws great wake when there are no passangers in the boat BUT the more people you add the more the wake gets washed out. Would more ballast placed around the boat help? I absolutely love this boat but maybe the 210 or 230 would be better? Any thoughts?
Took the boat out today and balanced the boat weight wise as best as I could then headed out on the board. Works much better. Speed also played a big part in keeping the wake right. Looks like balance and speed is the key. Thanks a lot for the responses.2008 SANTE 220
This may be too obvious, but make sure you have the lever for the wake plate pulled all the way back for wakeboarding, and forward for surfing or cruising.-Jon
16 G23
07 220 TE
05 211 TE
95 SS (210)
89 SN
my buddy has a 06 220, we have tried everything to get the boat to kick out a even wake with passengers. the trick is when you get a bout 10 people on the boat it starts to stick real low to the water and the hull can actually support that kind of weight. and it kicks out a even wake. with just me in the boat its dead even
CC Owned
1978 Ski Tique
1989 Ski Nautique 2001
1996 Ski Nautique 196
1999 Super Air Nautique (Python Powered)
2001 Ski Nautique 196 PCM GT-40 25Th Anniversary Current Boat PP Digital Pro 150 ORIGINAL Hours ( Current Model On The Lift )
Tow Rigs,
2002 Ford F-350 SRW Lariat 4X4 Crew Cab (Lifted 8" With 24" KMC ROCKSTARS ) ( Gotta Love Diesel Prices , That V10 Sounds Mighty Fine Right Now )
2007 Chevrolet Suburban 1500 6.0L LTZ 4X4 ( Bone Stock )
I spend about the whole summer two years ago riding behind and driving a 220. Loved the boat but I was starting to be convinced that the boat had additional weighting on the port side to counter the drivers weight. I loved this when it was just two people taking sets but when u got more I noticed the uneven washing too. Speed definitely helped and so did about 8 lead plates positioned all over. We put quite a bit in the nose and the rest we kept so the could be moved side to side very easily. Does anyone know for sure if the port side is weighted more to counter the drivers weight??1990 Sport Nautique
prop rotation causes the list you are speakin of...Originally posted by Kevin_BI spend about the whole summer two years ago riding behind and driving a 220. Loved the boat but I was starting to be convinced that the boat had additional weighting on the port side to counter the drivers weight. I loved this when it was just two people taking sets but when u got more I noticed the uneven washing too. Speed definitely helped and so did about 8 lead plates positioned all over. We put quite a bit in the nose and the rest we kept so the could be moved side to side very easily. Does anyone know for sure if the port side is weighted more to counter the drivers weight??
