xxrb2010 - My GTW is closer to 8500# (some lead, less than half tank of gas, gear, etc. - tongue weight and cargo weight similar to you. The calculator put me squarely in the 12000 WDH. I have no other math or calculations to help me get to that point. Equalizer website and calculator were my friends. Last summer we pulled the boat from Seattle to Lake Shasta (~600 miles each way) and the setup worked well. No issues. Other questions?
Thanks for the feedback,Originally posted by sixcampbells View Postxxrb2010 - My GTW is closer to 8500# (some lead, less than half tank of gas, gear, etc. - tongue weight and cargo weight similar to you. The calculator put me squarely in the 12000 WDH. I have no other math or calculations to help me get to that point. Equalizer website and calculator were my friends. Last summer we pulled the boat from Seattle to Lake Shasta (~600 miles each way) and the setup worked well. No issues. Other questions?
That is really helpful,
Bill
Originally posted by sixcampbells View PostNew electric over hydraulic disc brakes installed. After bleeding the brakes I took it out for a drive this afternoon - really impressed with how it works. Brakes work great - no lag, nomore "chunk" noise and impact of the surge brake actuator kicking in. I removed all the old surge actuator components and re-drilled and bolted in the original tongue. All in all not that big of a job. Well worth it!
can you talk more about how you redrilled the coupler afterwards to keep it from sliding? And pics on that part?
2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
nyryan2001 - 2 of the 3 original holes on the front side of the coupler did not change - so just re-used those. I had to drill through the coupler to install the third "stock" bolts and spring clips. I will go snap a picture as were planning to take the boat out later this afternoon.
Sweet thanks. Also... why did you choose the 1600psi version. Why not the 1000 or 1200psi versions?Originally posted by sixcampbells View Postnyryan2001 - 2 of the 3 original holes on the front side of the coupler did not change - so just re-used those. I had to drill through the coupler to install the third "stock" bolts and spring clips. I will go snap a picture as were planning to take the boat out later this afternoon.
is there a chart somewhere that bases the recommended PSI ratings on overall weight?2019 G23 450
2014 G23 550
2013 G23 450
2007 Yamaha AR210
I don't remember a sizing chart other than eTrailer recommended the 1600 for my triple axle boatmate trailer.Originally posted by nyryan2001 View Post
