I am using a Blaupunkt PA2150 tripath amplifier. Between the boat, car, & truck I have 7 of these amplifiers in use. They are small, run efficient, run cool but nothing to look at (which suits me perfectly).
At first they were wired in stereo, 8 ohm load on a 2 ohm stable amp, probably seeing about 75 watts each. The amp blew first time out. Yesterday I changed the amp out and changed the wiring to mono so the amp sees a 4 ohm load and produces about 450 watts. It works much better but they might be able to handle more. When/if the second amp blows I will step up to something a little more beefy.
I am an e-bay junky and saw the used Evids pop us with a $250 buy-it-now and I grabbed them. The Blaupunkt amps run about $90 on e-bay so I can afford to blow one or two. I used 4 conductor pro audio speaker wire (13 gauge) and it works/looks very clean (wires run inside tower legs). This is probably the best sounding boat system for what I have into it.
Haven't seen any more Evids on e-bay since I bought mine, but they are available new from internet suppliers for about $370, mine were used once at some kind of outdoor event. With Raul's clamps and wirecovers you are still under $500. Much more effective then trying to build some big bulky monolith box.
