Hello,
We have audio only coming from one side of the "cabin speakers". If I switch the RCA cables for that specific amp then the sound will go to the opposite side and only work on that side. The RCA cables come from a Wet Sounds Equalizer (WS-420SQ). If I switch the RCA cables at the back of the equalizer, same symptoms, sound only on one side. With new RCA cables- same exact symptoms. If I run the RCA cables for the tower amp out of the "cabin speakers" RCA ports on the equalizer then both tower speakers work. If I plug the RCA cables from the tower amp into the "cabin speaker" amp then only one side of the "cabin speakers" work.
System was installed by Hydrotunes in New Braunfels, Tx. sometime before we bought the boat.
Bad amp? Thoughts?
Amp is a JL Audio M600/6
Bad amp? Thoughts?
