I just got my boat. Was hoping it would be louder. Is there a common upgrade or amp upgrade I should do? I have the 4 8.8s I think they call it Elite Studio. Any suggestions?
You really should make sure the amps are set correctly first if that package has an amp. If so if the gain is turned down it will substantially reduce the performance and volume.
Sent from my iPhone using PLT Nautique2008 210 SANTE
Jl list how to set the gain using a volt meter. With that said, that does not mean that where the gain stays, May need to be dialed back after doing a live demo.What setting should it be at for max performance without distorting or damaging?
