03 SANTE DB651 install
  • dhanni848
    • Jan 2017
    • 254
    • Nashville, TN
    • 13 Super air 230 Team Edition 03 Super Air 210 Team Edition - Sold 88 Mastercraft TriStar 220 - Sold
    Replacing all of the cabin and tower speakers currently. I know there are plenty of posts on this out there, but it is kind of half baked and not pictured anywhere. Those that have done it, did you have to cut actual vinyl out or just the mesh. I think I read you cut the vinyl ring out that is around the mesh? Also, there is the ring you mount the speaker to, can pull that out, cut, replace, and put the speaker in. How much do I need to cut that to make the speakers more flush? Again, some info but not a good true amount out there. Any pictures would be greatly appreciated.
  • dhanni848
    • Jan 2017
    • 254
    • Nashville, TN
    no one
    • gobluemike2142
      • Jan 2017
      • 220
      • Michigan, USA
      • '96 SS
      I can't remember who posted it but it may have been kylem (sp?) or blamey. I think it depends how you want it to look. If you want the speakers more "flush" then you have to remove all that stuff and cut out some of the padding and re-wrap vinyl and all that. It looks great but def more work. Otherwise you can just surface mount the speakers after removing the vinyl.
      • kylem03
        • Jan 2009
        • 178
        • Wisconsin
        • 1983 Ski Nautique 2001 1994 Sport Nautique 1995 Super Sport Nautique 2007 Nautique 236
        Hey there, I did this on my 95 super sport and it requires taking out the consideration moving pads, unscrewing the pvc ring from the back, popping out the ring which the mesh and vinyl piping was staples to, re-attaching new shallow rings to flush mount the speakers, pulling the vinyl over the new rings and stapling, then installing the speakers from the front. I had a few pics in my post but it wasn’t comprehensive. I’ll try and link to it. Your 03 May be different though so results may vary.
        Kyle
        • kylem03
          • Jan 2009
          • 178
          • Wisconsin
          https://www.planetnautique.com/vb5/f...read-2016-2017
          • kylem03
            • Jan 2009
            • 178
            • Wisconsin
            https://www.planetnautique.com/vb5/f...peakers-in-san
            • distinguishedmotorsports
              • Aug 2016
              • 486
              • Austin, TX
              ?? if you are replacing some the polk momo speakers that were there from the factory they should fit no problem in the bow. the speaker inserts on say like a 220(?) and a 230 are designed for true 6.5" speakers, which means some the wide flange 6.5" are bigger than factory. in these 3 speakers on my 230 i just busted out my air dremel tool and shaved down the speaker inserts on the bottom of the speaker until they fit flush. i'll see if i can find some pictures of this.
              when it comes to placing the bigger speakers in the vinyl locations, you cut the foam baking for more room, leave the vinyl long so you can wrap it into the speaker hole.
              • dhanni848
                • Jan 2017
                • 254
                • Nashville, TN
                That is the post I have been looking at, and it is possibly different in my 03. May just have to dive in and see what happens!
                • Blamey
                  • Sep 2015
                  • 595
                  • New York
                  I have a post the details what I did. It's not the best but it rear mounted the db651 as the original speakers where rear mounted.
                  If your speaks are front mounted then the process may be a little different.
                  • Blamey
                    • Sep 2015
                    • 595
                    • New York
                    Here is the post,
                    Picks a little further done as the post started off asking for help. I front monted two MM6501s as the can't be rear mounted (did not flush mount so the speakers stuck out a bit.
                    I rear mounted the DBs. I used a plastic spacer on that I got off Amazon as the speaker fit better when using the ring vs mounting directly to the coaming pad.
                    https://www.planetnautique.com/vb5/f...sport-nautique
                    • dhanni848
                      • Jan 2017
                      • 254
                      • Nashville, TN
                      Thank you all
