Gang,
I finally got around to seeing how my the factory setup my stereo in my 230. Before we get into that, I basically picked every stereo option I could get in this boat. All the cabin speakers, 4 on the tower, subwoofer, transom remote, XM Radio, etc. I put as much into it as I could get.
The system comes with two JL Audio amps. A 600/6 and a 400/4. Owners manual: http://mediacdn.jlaudio.com/media/mf...pdf?1305758648
Here are the factory configurations for these amps:
400/4
- Drives the speakers on the tower
- Input Mode: 2 channel. Fed from "Rear" RCA from head unit
- Filter Mode: HP
- Filter Frequency: 80Hz
In this configuration, the tower speakers are not getting a full-range signal. They are getting everything from 80Hz up. Everything below 80Hz is filtered out.
600/6
- Drives the cabin speakers and subwoofer
- Input Mode: 2 channel. Fed from "Front" RCA from head unit
- Channels 1-4 Filter Mode: HP
- Channels 5,6 Filter Mode: LP (Bridged)
In this configuration, the cabin speakers are not getting a full-range signal. They are getting everything from 80Hz up. Everything below 80Hz is filtered out.
The subwoofer is getting everything from 80Hz down.
Proposed changes:
- I'm going to make one change at a time and see how I like it. As it comes from the factory, I'm wasn't wild about the sound I was getting from the tower speakers. It was all highs and when you're back there surfing, you can't really hear the subwoofer anyway. The tower speakers always sounded way too thin for me.
- For my first experiment, I'm going to set the Filter Mode on the 400/4 to "Off." This is a simple switch that I can always change back at any time. In the meantime, this will send a full-range signal to the tower speakers. I'm hoping this will give them a fuller sound for the surfer.
I'll reply back here with results.
-Charles
400/4
- Filter Mode: HP
600/6
Proposed changes:
-Charles
